April 04, 2025, 07:51:26 am *
Author Topic: XXHE 0.9z-8-1: Win7 taskbar not returning (after quitting unattended play)  (Read 10029 times)
nik.d
« on: January 19, 2013, 10:46:48 pm »
Peter hi,
Returned OS to 'normal' and installed/registered z-8-1 w/out problem. While in unattended and after hitting Alt-S and Alt-X commands
all I get back on screen is Library window opened. No taskbar, no desktop icons, have to restart PC for that.
The other thing to report: cover art is not showing but XXHE logo instead.
Started z-8e again - complained somewhat on Win state but no other issues, normally returns desktop on stopping/exiting unattended.
Here again, no cover art but XXHE logo shown.
Thks in adv.
« Reply #1 on: January 20, 2013, 09:44:59 am »
Hi George,
Did you install that W7Shell mentioned in the Release Notes ? You mention nothing of it, so I guess you didn't ?
Regarding the Coverart ... must be you somehow. Switched it off in settings (well, didn't switch it on ?) or play from a structure which doesn't allow for it ? But really nothing changed regarding this.
Let me know.
nik.d
« Reply #2 on: January 20, 2013, 10:38:25 am »
No, have not installed W7Shell - I'm still running Win7.
And definitly coverart is not related, it is album's photo file size. Tried z-8e with some new album and got the same: logo iof album photo/coverart: All my albums
contain 1 photo named 'Folder.jpg' with dimensions of 600x600 pixels. If file size is more than (not sure here) ~160-170kB, XXHE is not using it for wallpaper but
XXHE logo instead. Easy to solve - will reduce .jpg's quality Happy.
« Reply #3 on: January 20, 2013, 11:52:10 am »
No, you should reduce nothing George. But I can't imagine what has changed. With what version was this still okay ? (you don't need to sort it out, but if you just know it ...)
But what about that black screen now (Taskbar not coming back) ? Something sure changed there ...
Just tested it myself on W7, and you are correct ... Sh*t.
« Reply #4 on: January 20, 2013, 12:21:43 pm »
For those suffering from this (which should be anyone using Windows 7 or earlier and use Unattended with shut off Desktop Services), below there's a 0.9z-8-1a version of XXHighEnd.exe. Paste over your current 0.9z-8-1 version (and only that one !!) is sufficient.
The original download of 0.9z-8-1 has been adjusted for this as well (for those who did not download 0.9z-8-1 this will suffice, and below additional download will NOT be necessary).
* XXHighend-09-z81a-x.rar (1106.28 KB - downloaded 662 times.)
nik.d
« Reply #5 on: January 20, 2013, 01:22:13 pm »
That was fast. Thank you Peter, all OK now.
... Sh*t.
Smack ! And how many times I have to repeat: it is not Schiit, I'm proud owner of Phasure NOS1 !!! rofl
Coverart - below is the original (kB & pixel size) 'folder.jpg' that XXHE didn't like to convert to wallpaper. Have noticed in
several previous XXHE versions, could be even z6, but thought it's related to my older&cheap but passive graphic card...
BTW: give a listen to below album. At least in lazy Sunday afternoon...
drinks
