November 23, 2024, 07:50:43 pm *
Author Topic: 0.9z8-e Error messages  (Read 16720 times)
Diede
« on: January 12, 2013, 01:34:57 pm »
Hello Peter,
I've installed 0.9z8-e on my audio PC and everything works and sounds great!
Today I tried installing it on my desktop, and i ran into different error messages I can't seem to resolve even after re-installing.
When I press the S button to change some settings, XXHE goes into 'not responding' and I get the following error: "Error on obtaining GUID: Object reference not sent to an instance of an object."
I'm also unable to reboot in MinOS, I get the following messages:
"Error during Reboot: Object reference not sent to an instance of an object."
and
"We're sorry, but your reboot into minimised OS cannot continue. You may want to contact Phasure about this."
Please advice,
Diederik
« Reply #1 on: January 12, 2013, 02:23:45 pm »
Diederik,
I am thinking about what can cause it. That's why no response all the time ...
« Reply #2 on: January 12, 2013, 02:28:06 pm »
I can think of one thing now : no proper rights. So, is your UAC setting OK ? (all the way down)
Diede
« Reply #3 on: January 12, 2013, 02:33:21 pm »
This was my first idea also, so I already checked this and all is fine, lever all the way down.
Diede
« Reply #4 on: January 12, 2013, 02:37:29 pm »
BTW, something else happens which surely must be related. When I open XXHE the picture I have on my desktop background goes from 'Fill' to the original size???
« Reply #5 on: January 12, 2013, 02:50:29 pm »
I don't get it.
You are not running XXHighEnd "as Administrator" ?
(you should NOT do this)
Diede
« Reply #6 on: January 12, 2013, 02:53:38 pm »
I just manually rebooted my PC, and all of the sudden I'm in Minimised OS.  wacko
XXHE opened automatically, and I got the following message:
Check OS State: Something went wrong with the OS state!
The Minimise OS button as you see it now reflects the current propoer state.
The other problems remain however.
Diede
« Reply #7 on: January 12, 2013, 02:56:07 pm »
I am running as administrator Peter.
« Reply #8 on: January 12, 2013, 02:58:17 pm »
That may not be what I meant. You can "be" an administrator and you can runs programs by means of the selection 'Run as Administrator" (this is also a property to the program which you can set). This "Run as" should not be done (setting the property not either).
« Reply #9 on: January 12, 2013, 02:59:50 pm »
That will be because of an unexpected (inconsistent) situation happened.
But when you go to the Settings Area you receive those errors, right ?
Diede
« Reply #10 on: January 12, 2013, 03:05:42 pm »
Let me rephrase, my user account has administator rights, and the UAC is at never notify.
Diede
« Reply #11 on: January 12, 2013, 03:09:57 pm »
Yes.
« Reply #12 on: January 12, 2013, 03:10:18 pm »
Can you please be more precise about the part before the ":" ?
There should be a number in there as well ...
Diede
« Reply #13 on: January 12, 2013, 03:12:16 pm »
Error 01
« Reply #14 on: January 12, 2013, 03:28:17 pm »
Let's continue by email ...
