pistollero
« on: January 10, 2013, 11:03:54 pm » |
i have been listening to the same tracks on both and i donīt know what they are doing in spotify but the soundstage is super i can year on my audiotechnica ath-50 phones where the instruments are and itīs so clear. In xxHighend things are clear too but i not have de same soudstage. anyone have tested the same tracks on both??
Windows 7 home premium 64bit SP1 / asus n61v laptop / Engine#3 / Dev.Buffer = 1024 /*ClockRes = no*/Straight Contiguous/*SFS = 240*/not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 2 /-> audiophilleo2 -> dacmagic DAC -> active adam audio A8X monitors
ivo
« Reply #1 on: January 10, 2013, 11:12:02 pm » |
Hey,
This is a web-service. So, you say that music via web sounds better than via XX locally? I cannot test as Spotify is N/A in my country yet. Still, I do use Grooveshark and it sounds good, but it does not use KS, it runs via regular Windows audio path. Have not tried to compare Grooveshark sound to XX sound.
Ivo
pistollero
« Reply #2 on: January 10, 2013, 11:50:35 pm » |
the thing i feel is a big soudstage...my phones are closed, they donīt have big soundstage..but in spotify when i ear things around me in space outside my cans.. playing localy i donīt have the same soundstage and separation... iīm comparing to a streaming service beacause is where i feel diference.. localy the xxhighend is the best player for me. i donīt know if they use some sort of filter or something..
« Reply #3 on: January 11, 2013, 12:00:43 pm » |
Play MP3 and notice the same ... (I'm serious)
pistollero
« Reply #4 on: January 11, 2013, 06:44:01 pm » |
hi Peter, do you think they use some sort of filter to produce that soundstage feeling.?
« Reply #5 on: January 11, 2013, 07:10:18 pm » |
Well, first you could do is find out what's actually "transmitted". I don't know anything about Spottify but it can easily be MP3 of course.
But you better first agree about my MP3 experience. I could be the only one thinking this ...
ivo
« Reply #6 on: July 03, 2014, 12:45:02 pm » |
It's been a while since I last posted something here and maybe not good to say, but I have also not used XX for a while, too.
But, now Spotify is in my country and I do listen to it. Well, it sounds hell well - both - on my Android phone via Bluetooth phones (especially in extreme quality. I can afford that as in Latvia we have 6th fastest internet on planet, good coverage of 3G/4G and big enough data plans) as well as on my home (W7 laptop based with JKDAC32) setup (the one I used for XX before). I also use to listen via FM modulator in my car and it still sounds wonderful there. So, they manage to do some magic there...
About Spotify stream - they use OGG Vorbis encoding...
charliemb
« Reply #7 on: October 16, 2014, 02:20:50 am » |
My experience with MP3 is that is has a reduced, greatly reduced, soundstage.
Perhaps Spotify is assuming that listeners are using ear buds and they apply a binaural filter to simulate the soundstage. There is much magic that can be performed with this. I just bought a new car and the faux surround sound is great, with instruments all around.
July 2019: XXHighEnd PC (i7 3930K) Hyperthreading On (12 cores) clocked to 3.6GHz (100%), 16GB, Windows 7 Ultimate64 SP1 on 2.5 SATA2 SSD disk for OS and XX, music on 3.5 SATA3 7200 RPM. Motherboard BIOS settings: BCLK = 100 MHz / Intel Speed Step = OFF / Max Clock Ratio = 36 / Allow OS to change ratio = *OFF*. XXHighEnd 2.10 Adaptive / Q1/3/4/5 = 2/0/0/1 / Q1x = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Straight Contiguous / SFS = 30 (max 150) / Playerprio = Low (or below normal) / ThreadPrio = High / Core3-5 / No Playback Drive / No RAMDISK / UnAttended / most services Off, WASAPI on / Minimize OS / XTweaks set to v2.01 Defaults / 16x 768K Custom Filters (High) or ArcPredict DAC: Holo Audio Spring 2 KTE NOS DAC, and no preamp (also ISO REGEN powered by battery)
