April 02, 2025, 10:30:59 am *
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25  All
Author Topic: My first Windows 8 experience  (Read 341692 times)
« Reply #90 on: February 01, 2013, 02:06:54 pm »
I will get problems because W7 and W8 differs with the language. Or, Peter, is it sufficient/successful to install at W8 the identical language?
multi language package the English in there won't turn into German, let alone Finnish (which is of course what you use today - haha !).
thanx for the answer. It is possible with W8 to change the language now.
I  try to install the  W7 shell and hope that the new activation code will still work.
ed linssen
« Reply #91 on: February 01, 2013, 02:38:35 pm »
Hi all,
Is it advisable to go to Windows Update after having done a clean install of W8 from the DVD?
Thanks, Ed
« Reply #92 on: February 01, 2013, 02:39:25 pm »
Joachim, totally unrelated.
« Reply #93 on: February 01, 2013, 02:41:51 pm »
PS: When is someone finally going to give me another word for "softest" like used above ? Is this really the proper word to use ?
Quietest is the word I would use.
Hey Adrian, thanks.
« Reply #94 on: February 01, 2013, 02:51:09 pm »
The program for the  "W7 shell" installation for W8 works within the identical language only.
But you can change the language in W8 by installing the appropriate package. (Dutch / English)
« Reply #95 on: February 01, 2013, 03:17:31 pm »
Playing music with the W7 shell.
There is a mono effect, as mentioned by Peter, which is less when oversampling is not engaged.(44100 native sound)
Back to W7?
P.S. The overall sound is more agressive, perfect for Rock (Blind Faith  - Ginger Bakers drum solo in "Do what you like)
« Reply #96 on: February 01, 2013, 03:31:41 pm »
Hey Adrian, thanks.
Nah, softest is the word I would use because there is a relationship between the way we percieve both sound and touch. Softest captures that relationship best. Just my 2 cents....
« Reply #97 on: February 01, 2013, 04:02:13 pm »
Back to W7?
Joachim - Interesting ...
But please explain what you describe as "mono effect", because I said nothing of the kind and only the explicit opposite. And might you be confused by my mentioned "W7" earlier today (and its "mono") , this was nothing about the W7 Shell. Just W7 (it looks like you got confused by that ?).
« Reply #98 on: February 01, 2013, 04:36:58 pm »
Back to W7?
It was the first immediate impression. The room image is much smaller in width. (George Michael - Songs from the last century) The music is nearly mono with 16x, with the native sample rate 1x the room image improves.
The overall SQ is more aggressive, harsh, bass is more present (in concerts you do not hear that much bass). The sweetness/resinous of the violins is gone. (Rachel Z - The Trail of her blood in the snow)
I'm not quite sure if it improves with changes of my settings. I do not use PA (the components are all in phase)
« Reply #99 on: February 01, 2013, 05:01:21 pm »
Joachim, I know this sounds crazy, but my first impression of W8 with SFS of 430 is that it sounds harsh compared to SFS of 2! Have you tries SFS of 2?
« Reply #100 on: February 01, 2013, 05:10:26 pm »
It is not the harsh sound, in some kind I like it. The astonishing thing is, the room image is gone on my system, and the difference with 16x and 1x upsampling.
I'm just installing W7 for dual boot and will compare.
« Reply #101 on: February 01, 2013, 05:13:42 pm »
Okay, I was just wondering if you tried W8 with a SFS of 2 and compared it with a SFS of 430.
ed linssen
« Reply #102 on: February 01, 2013, 05:36:05 pm »
Hi all,
Thanks, Ed
Nobody is paying attention to my simple Q, sniff, sniff......
« Reply #103 on: February 01, 2013, 05:57:53 pm »
Hi all,
Thanks, Ed
This is Peters square.
I installed W8 on my laptop last year, and there are lot of updates installed in automatic mode, at least 20.
I would say no, but wait for Peter
« Reply #104 on: February 01, 2013, 06:01:02 pm »
Hi all,
Thanks, Ed
Apologies Ed. I myself don't know. That is, I use the download and it could be different.
Whether it's advisable in general ? I don't know either. I guess it's worth a try once you encounter strange problems of some kind. I do not or I don't recognize them. Happy
And anyway my PC isn't even connected to the Internet.
