April 02, 2025, 10:17:18 am *
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25  All
Author Topic: My first Windows 8 experience  (Read 341670 times)
« Reply #45 on: January 24, 2013, 09:21:44 pm »
I can't determine whether you now like this Yello track or not !
Liking the track? Not really (from a musical point of view)  but the effects and extra detail are as you described.
Even in stereo!  whistle
« Reply #46 on: January 24, 2013, 09:37:56 pm »
Oh boy. Yes, I listened to that in 2x Left as well.
Btw, also played that Bouncing Balls (ehm, same story) and as we know it could easily turn into a smearing beeping some sort of sound. Not so today; only at the very beginning of the "bouncing" (about half of the track) and at the very end it did some of that. Otherwise all stayed in order.
For others : this is no music but some kind if ultimate "square" speed test. When it doesn't work out, it creates wrong harmonics from the squares emerging and they smear.
« Reply #47 on: January 24, 2013, 10:45:02 pm »
So why the difference in SQ in W8?
« Reply #48 on: January 25, 2013, 12:09:19 am »
If I go for the cheap upgrade path, is a clean install an option? And if so, would you recommend a clean install?
<snip>
- I've always been able to use the less expensive MS "upgrades" to do a clean install.  I hope this one is no different.  I have not done more research into this, because like you, Mani, I like the sound on W7.
Here is a tutorial for a clean install with the upgrade:
http://pcsupport.about.com/od/windows-8/a/clean-install-windows-8-upgrade.htm
regards, Coen
« Reply #49 on: January 25, 2013, 01:21:04 am »
PS: I guess I better should not have said this about myself eh ?
I do believe that everybody can tell similar stories!!!
Sometimes it makes me wonder if I'm ................ .
« Reply #50 on: January 26, 2013, 06:31:23 pm »
W8 is up and running here. The OS upgrade, XX install and windows shell installs all went in very easily.
The sound is another very BIG step forward IMHO. I certainly recognise Peters observations (long post above). It's good to be getting the sweetest sound from high SFS and buffer and Q settings. I guess in theory it should work this way and it does. I was slow to move OS before (vista to W7) but I'm seriously pleased with this move.
More considered notes on sound to follow after some more listening  Happy
Mamba315
Ferrari NOS1a
« Reply #51 on: January 27, 2013, 02:44:16 am »
Hello,
  Quick question on trying Windows 8.  I can get any build through my work.  Do I just want the basic Windows 8 (not Pro, Enterprise, etc)?  Are you guys applying updates?
Are there instructions for the window shell install yet?
Matt
« Reply #52 on: January 27, 2013, 09:34:10 am »
Hi Matt,
Best would be to get Pro (or Enterprise). The basic version will not allow Remote Desktop which will come handy at some stage, and also I don't see any experience with that version yet. So you may run into problems which then are tough to solve (by me).
PS: Welcome !
« Reply #53 on: January 27, 2013, 09:49:37 am »
Hello,
Matt
Matt hi,
To give you a Target to try I I'll just say what I used.
The install was on W8 pro 64 bit (I happened to use update com earlier Windows media). No updates applied but my music pc is not internet connected after the OS has been installed, so   I am relaxed about security updates.
When I first ran XXHighend it needed Microsoft .Net installed so I let the pc download this. Also to use Peters Windows 7 shell instead of  the w8 metro shell (Peter says the metro shell has a bad mpact on sound quality) you will need to have a Windows 7 dvd to hand to for the shell install to copy the Windows 7 shell files from.  The Windows 7 dvd needs to be the match the bit level as the Windows 8 OS you installed (eg 64 bit or 32bit same as your w8).
Hope this helps and WELCOME
stefanobilliani
« Reply #54 on: January 27, 2013, 09:56:01 am »
I did install W8 pro 64 bit , did try some OS updates , about 4 of them with restore points , but they could be uninstalled from windows update for sure .
Regarding the little program contained in the last XX HE version for the " removing metro " stuff ( and having back a w7 desktop) , well I did find that it could be uninstalled leaving the file folder there . Then going to the minimized OS , the sistem will work just fine without the metro interface ; also lets understand that all the applications there in metro would not come up anyway when UAC is turned off which is mandatory for XX HE ..
Again regarding the Music Reproduction , with high sfs , all I can say is that I had a wonderful night on friday , well it was saturday morning . :-)
Beautiful reproduction , click free ,very very smooth and calm .
I did observed the task manager at some time in Minimized OS , of course , seeing that all the disks in the system were dead quiet .
It has been a long and beautiful listening , much better than the sfs = 2 , is now from 60 to 430 .
stefano
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #55 on: January 27, 2013, 09:57:56 am »
Oops, thanks Nick. I skipped a few questions I guess.
What I had in mind to say about the Shell : The XXHighEnd download comes with a small guide for this which by itself is referred to in the Release Notes of 0.9z-8-1(a).
« Reply #56 on: January 27, 2013, 10:03:46 am »
... With my notice that I don't trust a thing of all this TaskManager and Resource Monitor stuff in Windows 8. So, it tells something, but the intelligence to interpret it to its real merits is not for me yet.
Nothing to really worry about, but for me quite pain to get things right because I heavily depend on it.
« Reply #57 on: January 27, 2013, 10:47:51 am »
Peter, do you use the "Sysinternal Suite" ? It seems that a lot of people uses it and it is quite complete for many interpretations about what is happening "Under the hood"...
http://technet.microsoft.com/en-us/sysinternals/bb842062.aspx
Maybe this would help ?
« Reply #58 on: January 27, 2013, 10:52:34 am »
Alain thanks.
Oh yes I could or did etc. But this is not where my reference is. So, for me it is more important to see differences and with W7 etc. all was okay with the common tools.
It is also interesting to see (through) how W8 lets you judge, because I'm fairly sure that what's used is also used internally hence W8 uses it herself to "set(tle)" things. And now that will be wrong as well.
« Reply #59 on: January 28, 2013, 01:11:22 pm »
Yesterday I checked the latency of my PC with DPC latency checker (http://www.thesycon.de/deu/latency_check.shtml).
I noticed a strange peak repeating at intervals, but could not identify what was causing it. I deactivated a lot of thing in the Device Manager but it did not change a thing.
I have to confess that I am actually using a wired network for the moment, but I was not convinced it was caused by this.
Then, going again at the Thesycon website, I read this notice:
(quote from Thesycon website)
Windows 8 Compatibility: The DPC latency utility runs on Windows 8 but does not show correct values. The output suggests that the Windows 8 kernel performs badly and introduces a constant latency of one millisecond which is not the case in practice. DPCs in the Windows 8 kernel behave identical to Windows 7. The utility produces incorrect results because the implementation of kernel timers has changed in Windows 8 which causes a side effect with the measuring algorithm used by the utility. Thesycon is working on a new version of the DPC latency utility and will make it available on this site as soon as it is finished.
Just in case someone sees the same and wonder what is going on...
Page created in 0.022 seconds with 19 queries.
