April 02, 2025, 10:32:16 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25]  All
Author Topic: My first Windows 8 experience  (Read 341693 times)
« Reply #360 on: May 22, 2013, 11:19:40 am »
You are right of course. I think June 26th (2013) there will be some preview version out.
« Reply #361 on: May 22, 2013, 11:43:04 am »
Windows 8.1 will be for free for every W8 owner.
« Reply #362 on: May 24, 2013, 08:31:47 pm »
To be on the safe side (hence a sort of disclaimer) : I applied two (actually three) changes at the same time (stupid, but I couldn't test in proper fashion otherwise) : Besides adding the "PCI Supply Rails Noise" card I used an older Sharkoon USB3 dock for the hdd with music I wanted to try, plus I plugged this to the front USB3 "hub" while I otherwise I put the USB3 disks in the back port "hub", together with the NOS1. So, a different USB3 hub and a different USB3 hdd device.
And the "noise" card.
Hi Peter, I´m using W7 but I´ve made the changes you have done for W8 and my SQ improved notably. I had two hdd inside with music that were connected to SATA III, now none of these hdd are inside the computer and are connected to an USB 3.0 hub which is at the same time connected to a mb USB 3.0 port. The USB 3.0 hub is independently powered so it doesn´t take the power from the computer. The other change I´ve done, as you suggested, is to put the Playback drive inside the computer and connected to SATA III. Finally the Filter card remains where it was, filtering the TeckNet USB 3.0 PCIe card. Previously I had the Playback drive connected directly to the USB 3.0 TeckNet card where also was (and still is) connected the NOS1.
I don´t know about W8 but in W7 this changes made the best sound ever so far in my system, I´m now in the third day with this configuration and the SQ remains stable and sounding beautifully. The sound is clear, the soundstage firm and the bass tuneful, the final notes seem to never reach the end, they remain sounding lower and lower and lower until I can clearly hear where the sound stops. I don´t want to touch anything now, I wouldn´t like to touch it I mean, but...I suppose that the evolution will continue.
« Reply #363 on: May 25, 2013, 10:11:01 am »
Peter - Today I´ve installed XX in the W8 partition I had in the same hdd where I also have W7. I´m using exactly your W8 settings. All I can say so far is that it works, at this hour in the morning in Saturday I can´t play yet at normal volume level but the first impression is of a great sound. I´ll report after sometime about SQ, I know that I can´t experience the same as you due that you are using now a new XX version, but anyway so far it looks ok.
« Reply #364 on: May 25, 2013, 01:16:28 pm »
Well, all *I* can say is dat I yesterday removed the "PCI Noise card" and it *still* works here !
Of course I made it all confusing by posting about it in this topic as well as in the card's topic, but I honestly couldn't have both as a separate single subject, because the card DOES matter, and a lot !
But not for the better - not for Windows 8.
scratching
So to be clear : I now finally have W8 working in a fashion that I don't feel any urge to go back to W7. Not only that - W8 performs better than W7 now. It does so for the time I am playing with W8 again, which is close to a week. Trouble is : for most of the days this was with the PCI card in.
As you may have read from me in the card's thread "it can't go wrong, it sounds fully analog - FOR THOSE WHO LIKE THAT". Add to this the more or less blanketed feeling and you know what it is about.
No snap.
And this latter became very apparent when I removed the card and (this time) didn't change a single other thing.
Right away the square roar of Jon Lord's B3 was there and more so than I ever heard. It scared me a little because it seemed prone to too high dynamics again. But that didn't happen. Not last nigh at least and with nothing I tried to play for different types of music. Happy
The "snap" is key. Without that all is too refined and of not too much interest. Fact seems to be : the PCI card is doing this. So, what about a noisy (adding) beast ?!
It just has to be so.
Again I played Who do we think we are, and this time it sounded as I wanted it. All the singing was back, and the accuracy could be heard again. This opposed to the blanket which only showed "analog" and nothing much the accuracy of the NOS1 can show. Nice for many perhaps, but (as said in the other topic) quite braindamaging.
What a releaf.
But the best releaf is that W8 finally works (can work).
I still don't know for 100% what exactly "created" this, but it very well can be the usage of the other USB3 hub. So, NOS1 in its own - USB3 disks in its own.
Otherwise the XXHighEnd tweaks may be too many by now to interpret how what contributes, my 0.76Ghz processor speed not the least. It will be too hard to track back all. sorry
And I must say, all the little enhancements helped for sure, but I never really got there before. Now it works though, and people following my settings should be able to at least obtain the enhancements I achieved myself, outside the PC itself (which really allows for different stuff, sadly).
I changed my sig again with maybe emphasis on the "All Services shut off" which sneaked in there for the first dedicated W8 settings I put up, but which really can happen with 0.9z-9 only (but which I used for well over a month already).
Now let's put up that 0.9-z9 soon ...
