April 02, 2025, 10:08:56 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25  All
Author Topic: My first Windows 8 experience  (Read 341662 times)
« Reply #195 on: February 04, 2013, 05:26:24 pm »
PS:
In the mean time I'm, deliberately working on making it *worse* (again less noise from the OS). One never knows what will happen, is my motto. But it also may proove some things ...
« Reply #196 on: February 04, 2013, 05:49:17 pm »
Yes Juan. A LOT of work ...
I´m going to test the Playback Drive in a RAMDisk placed in a partition in the same hdd where is also XX and the OS and see what happens.
But this seems impossible to me. Happy
If you don't understand what I mean it was not a typo. Wink
Sorry Peter but I don´t understand...what I wanted to say is that I´m going to create a RAMDisk in the same hdd where XX and W8 are and use is as Playback Drive. What´s wrong with it?(besides my English of course  unhappy)
« Reply #197 on: February 04, 2013, 06:24:21 pm »
Ok, sorry I understand, the RAMDisck goes to memory.
I forget very often the technical issues, fortunately I have some mysterious help that reminds me all these things.
« Reply #198 on: February 04, 2013, 09:22:33 pm »
... for the life of me couldn't find the track anymore where it happened. I thought I knew which one it was though. And yes, later again in Minimized it sure was "that" track.
Would you mind sharing the name and source of that specific track?
« Reply #199 on: February 05, 2013, 12:04:59 am »
Pfoe, Win 8 and XXHE running a little better.
Sound is now possible through the motherboardconnectors.
Firewire and USB-HiFace not working yet.
So I'm listening now in Wasapi-style with portable(?!) headphones.
TDK WR700 really nice sound for little. (Wireless I should say, being tied to a wire is not my thing unhappy ).
Hope to get the others working too.
Solution looks to be related to hard reboot being different now and maybe sleep/hybernate. Some settings maybe only change after a reboot???
nik.d
« Reply #200 on: February 05, 2013, 12:25:32 am »
@mani
Just now finished fresh Win8 installation, have found the source of 'problem' with always active Win Startup Sound:
It's Windows 7 Explorer for Win8. Don't know if question/message about this to Tihiy (Ex7forW8 author) would help?
Now thinking of booting PC w/ Linux live CD and deleting original wave file(s) or editing them into silence? scratching
There are two instances under \Media folder, both protected system files.
Reporting further.
nik.d
« Reply #201 on: February 05, 2013, 01:31:34 am »
OK, annoying (& loud) startup sound solved - with brute force  smile
Booted into Ubuntu (Live CD) went into Windows directory and simply renamed two wav files 'Windows Logon.wav'.
Perhaps it's enough to rename first file only (found in :\Windows\Media sub-dir) but it's time to install XXHE, not booting Linux twice Happy
Second file was found in foll dir:
:\Windows\WinSxS\amd64_microsoft-windows-shell-sounds_31bf3856ad364e35_6.2.9200.16384_none_6fdc23973f4dcd1e
drinks
Jud
« Reply #202 on: February 05, 2013, 04:28:07 am »
PS:
Glad to hear you are making it worse.  Really.  Losing small choirs means to me it's not time yet to start using more noise to eliminate a sonic signature.  Right now that's just dithering around.  (My apologies - I do so love really horrible puns.)
Couple of ideas I haven't had time to try yet:
- If there's something weird going on with phase effects, how do things sound with adjustments to, or elimination of, phase alignment?
- How do XXTweaks affect system noise levels?  In particular, do tweaks like Balanced Load and Utilize Cores Always result in more system activity than there would otherwise be?  I suppose turning off Cool When Idle has got to lead to more thermal noise, but is it enough to have any effect?
« Reply #203 on: February 05, 2013, 08:46:02 am »
Air - Cherries - Track 5, Alpha Beta Gaga.
http://www.discogs.com/AIR-Cherries/release/265923
Do notice that Air, in general, exhibits all there is to exhibit from W8 anyway. No comparison with W7.
If you play this at -39dB (that's 7 bits less) like I did, it is plainly nothing less than superb.
« Reply #204 on: February 05, 2013, 09:30:26 pm »
Thanks, will have a listen eventhough -39dB is about 9dB less loud than at your place.
« Reply #205 on: February 05, 2013, 10:00:40 pm »
It's some 15 dB less loud than what I'm used to.
But new info will pop up tomorrow ...
« Reply #206 on: February 06, 2013, 11:42:44 pm »
Let me pop in before you Wink
Got everything working in 8.
Installed realtek motherboard codec drivers and restart made terratec work again. HiFace needed some 12V batteryjuice for the DAC which was gotten loose by all the moving around.
Sound? Incredible!
Listening to Anthony now, never liked it but now it's wonderfull.
Stereo picture reminds me of vinyl records that sometimes do strange things to the room, so I guess it's in the recording and now you can hear it.
Only not properly activated and sometimes the music skips some notes. But now on to enjoy some more!
« Reply #207 on: February 07, 2013, 08:51:12 am »
A bumpy LP can do that too !
Thank you for sharing Gerard. And good that you held on to it.
« Reply #208 on: February 07, 2013, 11:40:19 am »
So, here is my "pop up" :
Sound is now plainly nothing less than superb.
Do you hear ? grazy
Look at my sig as per the 5th of February 2013 and notice the ** denotations, indicating which parameters were changed compared to my previous settings (like I do it always with these **).
Yep, including SFS=2, meaning : I just tried that to be on the most nasty side possible, but it is not nasty. Not anymore and not at all. Never tried higher as of now.
Experience is from two evenings of listening. Could be too short to be 100% conclusive, but no way there's this aggressive sound anymore.
If I try hard I see the image maybe somewhat more towards the speakers, but no way it is coming from the plane of the speakers anymore.
Supposed I managed to dial in settings which are the best, but beter said : compare with W7 in general for best settings, then W8 is enormously better. It shows :
- More low *and* more tight bass (this combination is dangerous, that's why the *and*);
- Super square sound where it's intended without any spur of fatigue;
- Much more stereo and actually what we talk about all the time in here, but :
- The image is not strange anymore. L/R sweeps are there while not there at all in W7.
- Dark background is back.
With my settings (see sig) I think there's a tad too much metal in cymbals; it brings a general flavor to all the tracks of one album (not really disturbing but any flavor actually is or should be disturbing). Notice that the more severe case gives a same flavor to all albums which I think is not the case.
As a result of the too much metal, cymbals seem all too small. This should go away with higher buffer settings.
Summarized, I'd dare say that the sound now is *less* harsh then with W7 (if that was harsh in the first place, but just for comparison).
« Reply #209 on: February 07, 2013, 12:25:10 pm »
Removed switching supplies from everywhere ? You are not also talking about the PSU inside the PC ?  Shocked
You are not making it work with wax candles are you ?  grazy
