April 02, 2025, 10:32:20 am *
Pages: 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25  All
Author Topic: My first Windows 8 experience  (Read 341695 times)
« Reply #150 on: February 03, 2013, 02:12:31 am »
So I tried win8 too.
What a PITA!!!!
After regular problems like a DVD not starting as system, output of the BIOS going to another monitor I got it to work.
But now the volume goes down by itself.
When in desktop mode the corner mouse trick doesn't work anymore. When installing updates it starts with a question what browser you want and does not install it and stops doing anything.
No output from the highface so no idea what XXHE sounds like.
First tried 32 bit but it reported a problem with one of the music harddisks for which I should contact the manufacturer (Samsung!).
The harddisk light did not turn of. So I installed 64 bit and then problems only got worse. (Harddisk was ok now).
But I like the panoramas! Eiffeltower from beneath, Chicago beautifull.
So for me, Peter please make your own OS.
Even Win 7 is dying when I'm writing this.
Maybe we have to wait for SP1, but if it does not come soon MS will be dead.
Sorry for the negative mood but I think we should protect people from this frustration.
Eric
« Reply #151 on: February 03, 2013, 02:33:20 am »
Maybe your list of processes in the setting area is not correct?
Eric
Eric
« Reply #152 on: February 03, 2013, 02:35:52 am »
Eric
« Reply #153 on: February 03, 2013, 05:28:17 am »
Firstly, I just can't replicate anything approaching what Joachim and Alain are describing.
HI Mani,
On my system (with various settings) the soundstage is very weird. I hear a "ball" in the Center and attached the left and right speakers, very incoherent.
Micheal Bubles voice has a width of 2 meters, even if I sit in the sweet spot.
« Reply #154 on: February 03, 2013, 05:33:57 am »
NO, MS is supporting W7 with updates until 2020 according to their statement last year.
« Reply #155 on: February 03, 2013, 10:29:47 am »
Joachim,
Although at first you seemed to have a quite contradictionary description compared to my own (with your "mono" and such), this is by far the best description of how I perceive it.
What could be interesting is that I had someone over the other day who was not able to "see" what I see. We just couldn't agree upon me finding it all sh*t and him finding it all the best. Firstly it never happened before that I could not agree with whatever someone was telling from my system in my room, but secondly it may need experience (of your own sound) to "see" the weird difference. And in addition to that, possibly people can be sensitive to what happens. The resolution of the ear perhaps. Say, when one's resolution is not the best you won't hear a difference between left and right as how it happens with W8 (some fast switching as it seems). Then you'd have a normal stereo image I guess.
« Reply #156 on: February 03, 2013, 10:44:47 am »
You have 10 (that is TEN) hours left from of the time of this post ...
I am probably too late now but I am sure it has something to do with "stupidity" or some setting somewhere...
Settings for the USB driver? Again a switch set wrongly on the NOS1?
Just to name a few, could be anything...  Wink
« Reply #157 on: February 03, 2013, 10:47:09 am »
What a PITA!!!!
Hey Gerard,
Of course you experienced what you did, but I don't think this is normal or common. Should not happen at all.
But do you know that you need a W8 compliant BIOS ? This is not commonly known, but true. And from what you described it really looks to me that in that area something is wrong. So check your MoBo manufacturer for it !
Well, if you still have the guts. Happy
« Reply #158 on: February 03, 2013, 11:12:14 am »
So, here we go on the YAHOO !
You will know about my more often expressed thoughts about add noise to equalize a one source of noise hence profound "frequency" ? And what I told about "over the top".
Not being sure at all whether it is something like this now happening with W8 (too few noise sources) I thought about how to add boat loads of noise (sources) so it would randomize.
I must honestly add that what I next did I had to do for another reason actually, because I could not do what I am trying to do in the normal "environment". And next I thought, what the heck, it may work out for the better anyway, so let's try.
scratching
The thing I could not do, I couldn't do in Minimized OS Mode. Again I had been rebooting the whole day yesterday to get it done, and although I may have a clue by now, yesterday I had to give up and wanted to play with my new tweak. Do notice that I already had played with it in Minimized OS Mode, and that did not help much for my general (panning etc.) problem.
Long story short : I used Normal OS Mode, only shut off the Desktop Services, used my new tweak (which I think is rather irrelevant) and ... YAHOO !.
Right from the start I didn't perceive the strange "stereo" effect at sitting in front of the right speaker and otherwise .... what a RELIEF listening to indeed literal "palpable" sound. So SO normal. Phhhhhew.
Just W7, but with additional things for the better which I can't describe yet. But, I must add that I wasn't able (or didn't like to) dial in further other settings. All I did was bringing down the SFS of 430 and Q1 x Q1F of 30 x 30 to SFS=60 and 14 and 1 in order to have some more snap, while sure the higher settings did not sound muffled (which W7 tends to do). I couldn't try SFS=2 because of my other tweak, but I'm sure it would have worked out for the better.
Do notice that when in Normal OS Mode various other tweaks can't work, amongst that XTweaks. So, it is a large pile of apples and oranges in the first place. But point is : it works for its purpose (add noise) and the workout is as I "planned" it.
Watch out : Although everybody should try this, it should work out for the better only for those perceiving the "panning" problems in the first place. This is about a few people only (as how it looks). For the others I'd say, leave it as it is, but still it is easy to try and you may find it more "normal" at the same time. Do notice though that there is a difference between more normal and the actually f*cked up sound of W8 (which I described earlier as straining). So, f*cked up in the sense of too much boosted. Not easy to listen to. Tirering. Much detail, but too much of it. Try to see whether you also can perceive that RELIEF like I got it.
Anticipate other parameters to play a role suddenly, more than before. Could be Clock Resolution.
Strange tweak, don't we think ?
« Reply #159 on: February 03, 2013, 11:20:03 am »
Do not forget : This is not only about Normal OS Mode, but also about NOT stopping the Remaning Services. Desktop Services yes.
« Reply #160 on: February 03, 2013, 11:28:54 am »
That means that I can use the Windows Volume Slider to adjust the volume...is that a good thing?
Okay, a whole new start here where all settings indeed will have their influence again. Then better have latency as low as possible to start with as that seemed to sound better in the "old" days to start with...  unhappy
« Reply #161 on: February 03, 2013, 11:31:45 am »
No ...
But what to do (but this sure must be looked into !).
« Reply #162 on: February 03, 2013, 11:58:24 am »
After some minor hickups (stopped playing after a few seconds and such) and some rebooots things play okay now and... WOW!
Regardless that W slider I have to admit that this sounds 300% better to me. Piano has got its weight again...hell, everything got its weight back again and gone is that flattisch holding back "noisy" sound (W7 basically the same...).
F*ck those fake details... I even seem to have more real detail now but I need to listen more for some useful feedback!
EDIT: I do not have the feeling anymore to add some colouration to the system to make it sound nicer to the ears. Nothing wrong with these speakers!  Happy
« Reply #163 on: February 03, 2013, 12:09:51 pm »
Just to be sure I understand...
- Normal OS
- Stop Desktop Services = yes
- Stop Remaining Services = no
- Lower SFS
- Lower Q1 and Q1 factor
I got it right ?
« Reply #164 on: February 03, 2013, 12:24:24 pm »
Alain, yes. And notice that the lower buffers etc. is just to "dial back in" the more snap from W8 as we learned it can be there. A bit of a mind thing I guess and undoubtedly depending on the music. Well, nothing much different from how we dealt with W7 I guess ...
