November 23, 2024, 11:58:29 pm *
Pages: 1 2 [3]  All
Author Topic: New download 0.9z8-d available  (Read 32928 times)
0 Members and 12 Guests are viewing this topic.
« Reply #30 on: January 06, 2013, 01:53:55 pm »
Thank you Alain.
That "insert DVD part" will be because of the necssity to install Dot-net 3.5 which is not automatically installed with W8 (4.0 is). But you should have received the same sequence at earlier (fresh) attempts ?
« Reply #31 on: January 06, 2013, 02:12:00 pm »
Thank you Alain.
Ah... Sh*t ! I should not only read the fine prints, but re read them ! I remembered that I needed to install net 3.5, but instead I downloaded it. I had to retry quite a few times, with an error message telling that there was a problem while attempting to download it... But it finally installed, though I do not recommend it (because of all the failed attempts)...
Thanks for reminding this... Next time (I hope there will be no next time)... To be on the safe side, I did an Acronis with XXHIGHEND activated, so I should be quiet with the activation process... Wink
« Reply #32 on: January 06, 2013, 02:32:11 pm »
Don't be bothered by that z8c-01; just paste over the 0.9z-8e over your current XX folder.
Ok ?
Ok, I did it and the ticks are gone (except the tick before the first track that now seems weaker). In the GUI appears XXHighEnd 0.9-7-5 (C:\XXDownloads\XXHighEnd\XXHighEnd-09-z8a)
Nothing about the 0.9z-8e installed. Is that correct?
« Reply #33 on: January 06, 2013, 02:49:38 pm »
No.
If you really pasted over any 0.9z-8 folder, check your shortcut ?
« Reply #34 on: January 06, 2013, 02:55:35 pm »
I did something wrong installing the 0.9z-8e without Minimize OS. Now I have some problems. Minimize OS doesn´t engage.
Now I have to go away for a while, I´ll be back in a couple of hours.
« Reply #35 on: January 06, 2013, 03:02:27 pm »
By the way: I haven't tried again the dongles for Bluetooth connection, but I will and report the results... It did not work the first time, no matter what compatibility I tried (XP, Vista, W7)...
Nothing changed about that. Except for I have found a driver which works here. Will send it to you by email.
« Reply #36 on: January 06, 2013, 08:12:02 pm »
No.
Yes, I was using a wrong shortcut. Now all is ok and there are no ticks, not even the one at the beginning of the first track. The sound seems to be cleaner than before.
Pages: 1 2 [3]  All
Page created in 0.132 seconds with 19 queries.
