November 23, 2024, 09:41:55 pm *
Pages: 1 [2] 3  All
Author Topic: New download 0.9z8-d available  (Read 32897 times)
Stanray
« Reply #15 on: January 06, 2013, 01:12:03 am »
No restore point for 0.9z8-a, Robo?
Stanley
Robert
« Reply #16 on: January 06, 2013, 01:44:22 am »
No didn't work. I should have set restore prior to loading z8d. Yes hard lesson not creating a restore point prior. Does this mean a new OS install and online activation etc argh???? I tried after reading all minimise OS forum words, all advice offered, but no good.
It all went wrong when I dropped d files over a but XXhighend was still in minimised OS. It only plays 4 songs then stops also. Gone back to z7 now works fine. I suspect OS with z8 is corrupted. Its become too hard I've spent too much time on this today.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #17 on: January 06, 2013, 05:34:58 am »
All is working fine with Windows 8. I was able to MInimize OS with no problem Happy It was all those services that I deactivated that created problems when I did my attempt today. I also had to get a new activation code (for the same reasons I guess).
« Reply #18 on: January 06, 2013, 10:45:56 am »
Robert,
I don't see how this can make sense (I don't mean your sentence, but the happening). It is something I do 200-300 times per day, really (a new build and try). It may be a psychological thing because you (all) were told earlier that you shouldn't be in Minimized Mode wgen upgrading etc. But a. this should not matter anymore (but could) and b. this is not something which behaves as an update. Just replace some programs and it does nothing.
Undoubtedly something "bad" happened to you, but it hardly can be this as the cause.
This looks strange as well. When you went into Minimized with 0.9z-8a there (say, last week), did you deny the question for making a Restore Point ? This is not what you are saying, but assumed you just allowed for it, it should be there.
But what to use it for ? beats me. I guess we have come to a stage that better understanding is needed, especially because things got more easy (! ?).
I don't know what to advise at this moment because I don't have real data (as to why you can't get Minimized and such). I can tell though that chances look 99% that you are not activated anymore and *that* can easily be because you did other than "just applying that zip" ?? E.g. create a new folder first maybe ?
But anyway Robert, when you can't Minimize, please tell why. Messages ? just the exact sequence. And check whether you are activated of course.
For symantics :
I've deleted and reloaded fresh activated installs of z8 a + d versions still no minimise OS.
You can't have. Not to the letter. To me this tells a few things. Similar here :
I've tried going back to z8a and that won't minimise either.
How ? You sure can, but again, chances are far more that you applied this otherwise and lost activation.
Hey, not to blame you for it of course, but only trying to explain what can be going on. Ok ?
« Reply #19 on: January 06, 2013, 10:51:27 am »
Also, the wallpaper now seems "glued" to the desktop.
Stanly, question in between the lines : is this with Windows 7 ?
« Reply #20 on: January 06, 2013, 10:59:00 am »
When I start AND when I close 0.9z8-d I get this message:
When you unzip the below over your current XX folder, does the error stay away ?
* ChangeWP-09-z8e-x.rar (32.01 KB - downloaded 506 times.)
« Reply #21 on: January 06, 2013, 11:03:48 am »
Thanks for that feedback Alain. I just want to notice that including "your tweaks" -though generally- it still should have worked (think about the "Going back to YOUR original settings" message/question). So :
Can you remember and tell me what actually did not work. How it did not work, and whether it looked 100% the same as the 0.9z-8a experience you encountered at first ?
This is not crucial to know, but since I like it not to go wrong for anyone ...
« Reply #22 on: January 06, 2013, 11:36:04 am »
I was having problems with WP but now with 09z-e-x installed all is OK. To get rid of error messages I just had to completely reinstall so my problems might have been local to me. Anyway all is OK now with latest WP.
Stanray
« Reply #23 on: January 06, 2013, 11:39:02 am »
Yes Peter, Windows 7.
Stanray
« Reply #24 on: January 06, 2013, 11:41:15 am »
Yes, the error stays away now.
Thanks Peter.
« Reply #25 on: January 06, 2013, 12:06:36 pm »
Do we need any help on this ?
(can lay out a procedure to get that right I mean - but do you still have this problem ?)
Stanray
« Reply #26 on: January 06, 2013, 12:52:39 pm »
All is working fine now. No problemo.
Thanks
Stanley
« Reply #27 on: January 06, 2013, 01:40:14 pm »
It behaved the same way as it was doing with 8a - no display at all. And yes it was with the files from 8d, because when I initialized W8, copied the XXHIGHEND folder back and started it, it was indicating "8d".
During Christmas time, I exported all the original services in an excel file (to have a reference) and started deactivating many of them. After I exported that new list again and made an excel file with different columns to have a view of what was changed. At the end, I had a little under 20 services working, but I knew I would eventually run into problems when Minimize OS would work.
I may have deactivated a service that was related to the restore function, because when I tried to Minimize OS yesterday, an error message popped saying that it was not possible to create a restore point. Nonetheless I decided to go forward. Then...
At this point I should have used F8 but from what I experienced before, I decided instead to restore from an Acronis backup. It was a PITA to make F8 work, so I skipped this part.
After the Acronis restore it was easy to initialize and I could verify that it was working well. The only surprise came from the fact that I had to insert my W8 installation DVD, because it seemed that some files were missing (?).
Ah... And since I had deactivated the DVD reader/writer from the Device Manager, at first the initialization was not starting Wink I had to activate it - something not to forget Happy
By the way: I haven't tried again the dongles for Bluetooth connection, but I will and report the results... It did not work the first time, no matter what compatibility I tried (XP, Vista, W7)...
« Reply #28 on: January 06, 2013, 01:44:56 pm »
Sorry but with so many celebrations these days I´m a little lost. I installed the main 0.9z-8 version and in the same folder the z8c-01. I don´t know if now I have to jump directly to the last 0.9z-8e version and unzip it in the same 0.9z-8 folder together with the z8c-01 that´s already there.
Can someone clarify it please?
« Reply #29 on: January 06, 2013, 01:51:58 pm »
Don't be bothered by that z8c-01; just paste over the 0.9z-8e over your current XX folder.
Ok ?
Pages: 1 [2] 3  All
Page created in 0.137 seconds with 19 queries.
