November 23, 2024, 09:27:10 pm *
Pages: [1] 2 3  All
Author Topic: New download 0.9z8-d available  (Read 32896 times)
« on: January 05, 2013, 08:13:57 pm »
For 0.9z-8a, b or c users : A new 0.9z-8d is available for download.
It is obtained at the bottom in the original 0.9z-8a download.
« Reply #1 on: January 05, 2013, 08:28:47 pm »
« Reply #2 on: January 05, 2013, 08:33:25 pm »
Sorry Peter, from the size of the download, I assume that it simply has to be installed over the last version ?
« Reply #3 on: January 05, 2013, 08:35:45 pm »
Oups... Like you already told me, I forgot my new year resolution... Always read the small prints Wink
« Reply #4 on: January 05, 2013, 08:39:12 pm »
Still, better stop smoking.
Just cigarettes, that 'll do for a good helth.
haha
But the answer is Yes of course.
« Reply #5 on: January 05, 2013, 08:42:06 pm »
haha
My doctor would approve you Wink
About Minimize OS with W8... Still not ? I prefer to ask instead of trying...
« Reply #6 on: January 05, 2013, 09:03:05 pm »
Well, WT.
Did I forget about that in the Release Notes then ?
swoon
« Reply #7 on: January 05, 2013, 09:09:50 pm »
Well, WT.
swoon
Well no, not really (you did not forget). So I tried... Did not work... I am reinitializing the PC right now, because I did too much stuff before, so maybe this explains why it does not work still ?
Anyway, I will keep you posted Happy
« Reply #8 on: January 05, 2013, 09:17:15 pm »
WHAT !!?
« Reply #9 on: January 05, 2013, 09:19:51 pm »
Maybe check whether you see "0.9z-8d" in the title bar ?
Seems unbelievable to me. But about your other tweaks ... I can't tell.
Alain, I'm off here for several hours now ...
Anyway sorry for your troubles ...
PS: Still no acces to the Restore Point ? (F8 and such)
« Reply #10 on: January 05, 2013, 09:25:27 pm »
Please not worry about me. I was not able to create a restore point, but I am quite sure I did something wrong long before I attempted to install the latest XXHIGHEND.
I will simply reinstall from a backup and start from scratch. It's not a big deal Happy
I will post my results. And if it is tomorrow, no problem either Happy
Alain Happy
Stanray
« Reply #11 on: January 05, 2013, 10:07:24 pm »
When I start AND when I close 0.9z8-d I get this message:
ChangeWP
=02= System.ArgumentOutOfRangeException: Index and length must refer to a location within the string.
Parameter name: length
   at System.String.InternalSubStringWithChecks(Int32 startIndex, Int32 length, Boolean fAlwaysCopy)
   at (Object , Int32 , Int32 )
   at A..(Boolean& , String& , String& , String& )
OK
Stanley
« Reply #12 on: January 05, 2013, 10:48:21 pm »
Stanley,
I sort of expected this. I applied a quick tweak which wasn't totally legal. I hope it goes away with not applying Wallpaper stuff ...
Thanks !
Stanray
« Reply #13 on: January 05, 2013, 11:20:56 pm »
Also, the wallpaper now seems "glued" to the desktop.
Stanley
Robert
« Reply #14 on: January 06, 2013, 12:52:10 am »
I concur with Stanray but worse I can't get mimimise OS to work.  I've tried going back to z8a and that won't minimise either. This is with basic settings no tweak settings. z8a was working fine last night with all the settings showing in my profile. I've deleted and reloaded fresh activated installs of z8 a + d versions still no minimise OS.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
Pages: [1] 2 3  All
