April 06, 2025, 12:12:07 am *
Author Topic: What will a PC upgrade do for the SQ  (Read 24761 times)
Arjan
« Reply #15 on: February 16, 2013, 04:16:40 pm »
Thanks for the info. That was also my first choice, because I saw that it was a be quiet! on your pictures. And then I started thinking, this can be improved......but I lack the experience.
kind regards, Arjan
March, 2024 (2.11)
« Reply #16 on: February 16, 2013, 04:58:10 pm »
And it is just that experience. I have that Nexus and 3 others here, all failed ...
And hey, aren't that supid reviews/tests ... The Nexus is the most silent. Yea, when you don't listen to your amplifiers.
Stupid stuff.
« Reply #17 on: February 16, 2013, 05:31:02 pm »
Stupid stuff.
Right. The problem is: when they talk about noise, they too often only mention the incoming noise from the device... Not the noise that spreads into the signal and pollutes the rest...
Jud
« Reply #18 on: February 16, 2013, 08:13:37 pm »
In the XXHighEnd PC the BeQuiet! Pure Power L7 530W is used.
Notice : The reason for exactly this one is not only it being quiet enough, but also it providing enough power connections and merely : it's smaller size. When the size is not of the most importance, others may suffice just as well.
For folks in the US: The OEM for the BeQuiet! stuff in the power range for Peter's PC is a Taiwanese company whose name I forget at the moment.  At higher ranges the OEM is Seasonic.  They're both available through Newegg and other US sources, so you wouldn't have to pay to import from Germany if wanting to build your own.
Jud
« Reply #19 on: February 16, 2013, 08:19:37 pm »
FSP is the Taiwanese OEM.
