April 05, 2025, 11:47:33 am *
Author Topic: What will a PC upgrade do for the SQ  (Read 24744 times)
Arjan
« on: January 04, 2013, 10:19:58 am »
Hello,
I am thinking of upgrading my Netbook to a dedicated highend music desktop. E.g. Intel 3930K with 16 Gb memory, SSD and SataIII.
I like to hear of experiences of other people who did that in the past. Will the SQ go up and how much? Or is it only glitchless playback that will be improved?
kind regards, Arjan
March, 2024 (2.11)
« Reply #1 on: January 05, 2013, 12:15:02 am »
Hi Arjan,  regarding XXHighend, in 2007 I started with a Dell Vostro 1500 laptop with 2 gigs of memory. In 2009 I switched to a Vostro 230 with 4 gigs of memory. In the spring of 2012 I put together the computor in my signature below. I found each change, particularly the last, significantly improved sound quality.  You should take a look at this thread started by Juan: http://www.phasure.com/index.php?topic=1673.0
Tons of good info there.
« Reply #2 on: January 10, 2013, 10:39:19 pm »
Yep, SQ should improve.
xxhe likes many cores and lots of ram to load bigger portion of files (although sometimes low SFS are more liked by the community)
4 cores and 8GB would be the very minimum If i were to build my dedicated PC now.
Arjan
« Reply #3 on: January 16, 2013, 12:21:33 am »
Hi Boleary and Telstar,
Thanks for your answers. So my next upgrade will be a dedicated music PC.
kind regards
March, 2024 (2.11)
Arjan
« Reply #4 on: February 14, 2013, 11:43:24 am »
I am working on the selection of components for my new audio computer. But I need some advice. I have a couple of options but will limit it to two basic questions.
1) Go for a fast processor. A computer more or less similar to the one build by Peter last year. Based on a 3930K intel (130W). But a pc like that will need fans to cool and heavier power supply, and so on.
2) or go for a passive computer with e.g. a 3770T intel (45W) processor. This can be completly passive.
The question: will the faster processor with active cooling but 6 cores be better for SQ than the passive PC with a 4 cores processor, although passive.
I really like the idea to go for the second (passive) solution, just a good mobo, processor, 16Gb, HDD, SSD and small power supply, in a streacom case.
Any advice available?
regards, Arjan
March, 2024 (2.11)
« Reply #5 on: February 14, 2013, 12:33:17 pm »
Hi Arjan,
I would never go for the "slow one". It will be too slow to conveniently play music, and besides you will be limited for certain settings which are SQ related. So, SQ in general may (or may not at all) be influenced negatively, but it is about the stupid thing of e.g. receiving gaps at good-SQ settings because all is too slow, while "we" are able to dial-in those good-SQ settings.
I hope you can understand it. So, indirectly it is always SQ related and the faster the better. Just because you will have more options.
Stanray
« Reply #6 on: February 14, 2013, 03:26:22 pm »
Hi Arjan,
A year ago I faced exactly the same question, speed or silence.
In an attempt to find a fast but silent solution I chose for the Intel i7-2600S (95W). It seems like a tuned down version, but is overclockable.
It is cooled with an oversized cooler, the Thermalright AXP-140RT with a NoiseBlocker 120mm silent fan on top. This is the only fan in the pc. The PSU is a fanless Silentmaxx Fanless II.
It all works great, I had no issues with the common XX settings and the pc is very silent. The choice of the cooler and fan is of course dependent on the type of pc cabinet.
All was ordered at Informatique .
Stanley
Arjan
« Reply #7 on: February 16, 2013, 12:55:14 pm »
Thanks again for the replies. I ordered the components for the audio PC. The basic mobo, processor and so is similar to the pc created by Peter last year. I will use a Nexus 5000 r3 power supply, it has a fan but is well known for its silence. I use a Silverstone milo 03b case, a 10 cm low case, I will add two case fans, but maybe not use them, lets see. The cooler will be a scythe shuriken 2 rev b with PWM controlled fan, this is my only concern. It seems that the only cpu fan controls today, for X79, are PWM, but this can interact with the SQ. Any thoughts on that?
This audio pc will replace my current netbook, I am really curious to find out the improvements!
regards, Arjan
March, 2024 (2.11)
« Reply #8 on: February 16, 2013, 01:04:14 pm »
Arjan,
While you can, cancel the order for the Nexus. It creates DC Offset on the mains ...
It is silent, but now your (amps etc.) transformers won't be ...
« Reply #9 on: February 16, 2013, 03:19:06 pm »
Hey Peter Happy
This Nexus thing is quite interesting. How about the Seasonic brand ?
Is there a place where you listed the grocery list for the music pc you made ?
Arjan
« Reply #10 on: February 16, 2013, 03:38:56 pm »
Interesting remark on the Nexus. Do you have a better brand in mind, e.g. be quiet!. Or go completely passive with a seasonic?
regards, Arjan
March, 2024 (2.11)
« Reply #11 on: February 16, 2013, 03:41:21 pm »
Hi Arjan,
Seasonic is great. Take a model over 500W, it has extra capacitance over the "smaller ones. Quality comes with a price though.
Also the Corsair dsp 7xxW units are worth investigating.
Regards, Coen
« Reply #12 on: February 16, 2013, 03:45:19 pm »
I got the Sesonic Platinum model with a 1kw rating. Not that such power was required, but I thought that the more powerful the PSU, the less chance the PSU fan would run...
« Reply #13 on: February 16, 2013, 03:51:58 pm »
In the XXHighEnd PC the BeQuiet! Pure Power L7 530W is used.
Notice : The reason for exactly this one is not only it being quiet enough, but also it providing enough power connections and merely : it's smaller size. When the size is not of the most importance, others may suffice just as well.
« Reply #14 on: February 16, 2013, 04:03:56 pm »
Thanks Peter. I was wondering (and this reflect my ignorance, but anyway): if a PSU would induce DC offset, would it reflect when we check the DC offset of the NOS1 ?
