November 24, 2024, 04:37:54 am *
Author Topic: 0.9z-8 Unattended Alt-N (next track)  (Read 8980 times)
Tore
« on: January 04, 2013, 12:12:21 am »
Hi Peter!
I use the same settings as you do.
When i load a album and start plying in Attended i get this message: because of you settings only one track will play
When i press Alt-N in Unattended the screen is going back to XXHighEnd (Attended) and i can see that next track is selected. Then music stops
Tore
« Reply #1 on: January 04, 2013, 12:37:32 am »
Hi Tore,
You must take it that when this message appears, Alt-N won't work either. I should add that to the message -somehow- (which would really be inconvenient, because when using Unattended no message should appear while exactly there it's useful) ...
Tore
« Reply #2 on: January 04, 2013, 10:28:01 am »
OK, i tought my PC was to old.
Will you solve this?  I`m use to that button (next track)
Tore
« Reply #3 on: January 04, 2013, 11:12:07 am »
Tore - I regard it Impossible.
But don't tell anyone that I am playing with SFS=2 and the low buffer sizes again for a day or 5 by now. It's a secret. secret
So with the not crazy high SFS / Buffersize combination Alt-n just works okay.
Tore
« Reply #4 on: January 04, 2013, 12:03:11 pm »
I have checked here with buffer size 4ms and SFS=2
The lowest SFS i can play Unattended with is 55, but it is the same problem with Alt-N
Tore
« Reply #5 on: January 04, 2013, 01:30:26 pm »
Okay, I wasn't clear;
It is about the Q1 x Q1Factor x Device Buffer Size (in Settings). The factor-total of this must be lower (like 14 x 1 x 4096 will be OK).
« Reply #6 on: January 04, 2013, 01:32:57 pm »
PS: I said it would be impossible to let Alt-n work for these super-high settings, but it is merely that I don't see priority in it for the upcoming time. This really is difficult stuff and I know from myself that I'll accept Alt-n not working once I find the SQ better anyway (which latter is not what I want to put through your throat !)
Tore
« Reply #7 on: January 04, 2013, 02:29:07 pm »
It is working now, thanks again
Tore
