November 23, 2024, 09:38:43 am *
Author Topic: Reboot Minimized OS issue  (Read 10728 times)
listening
« on: December 26, 2012, 04:56:14 pm »
now I found the time to recover from Christmas  Wink  and tried to install the new version. I run into problems:
1. Switched old version to normal OS
2. Copied new version to PC
3. Activated version and did the configuration
4. Rebooted the PC - seems ok
5. Pressed the Button "Minmize OS"
6. Did the restore point
7. Then the message window "Check reboot" appears:
"Were sorry, but your reboot into Minimized OS cannot continue"
So what to do  scratching
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #1 on: December 26, 2012, 05:34:11 pm »
Hey Georg,
What to do ? ehm, get your Activation right ? It sure looks like that is not the case.
listening
« Reply #2 on: December 26, 2012, 06:04:10 pm »
Hey Peter,
in the meantime I measured the room resonances for a new loudspeaker, had to reboot the PC two times - that's it. Activation needs sometimes more carefulness or more popular: The problem is sitting 40 cm in front of the display  Wink
Georg
-> SMSL SU-8 ES9038
henri21961
« Reply #3 on: December 27, 2012, 12:30:23 pm »
good Morning
I have the same problem with min os  , everthing going til he will shut down  and start again, but then I get information I may have contact with you.
with friendly reagards
Henri
listening
« Reply #4 on: December 27, 2012, 01:15:48 pm »
Hi Henri,
sometimes it was helpfull in my system to start the old version again, stop it, shutdown the PC, boot the PC again and start the new version. If you are using the unattended mode it is possible to show the album cover. If the cover shows a red frame you are fully activated and you can reboot with minimized OS.
Georg
-> SMSL SU-8 ES9038
« Reply #5 on: December 27, 2012, 01:54:18 pm »
Hi there Henri,
I know this message exists, but not in the literal sequence you just described. So you really have to be more specific about what you do and when this message appears. Probably all starts with you pressing the MinOS button and your "starts again" does not mean "after the reboot". This merely will be the screen coming up after being black for a few seconds.
So ?
PS: And please don't answer "yes you are right" or "I have the same problem". Instead, try to describe what you try to accomplish, what you do and what you see happening. Ok ?
henri21961
« Reply #6 on: December 27, 2012, 02:28:59 pm »
hello Peter
I push on the button min os , he start to backup , and I get the information that he made a backup xxhighend OS  , and starts to close down ( black screen ) than popup a screen that it faild and  that I can contact you,  thats all
he will play on unatt. mode ,
I can also thry min.os whith a older xxhigh end, but than I don't have the tweaks? what will popup  with the 9.z8
friendly regards
Henri
« Reply #7 on: December 27, 2012, 02:35:25 pm »
Thank you Henri.
Are you properly activated ?
And ehm, did you ever try to reactivate for 0.9z-8 ? (this is necessary)
henri21961
« Reply #8 on: December 27, 2012, 10:06:01 pm »
Hello Peter
 :)It's working after a new instal. and activation
very well
Thanks for the time and support
it's still better than jplay.......
Page created in 0.122 seconds with 19 queries.
