April 05, 2025, 06:07:21 am *
Author Topic: Using XX in XP  (Read 29672 times)
andy74
« on: October 24, 2007, 10:27:00 am »
Anyone using XX in XP?
What do you think is the best SQ version/engine# for playback on XP?
...failed to find such discussion here. Most people talk about Vista and engine #3.
Andrey
andy74
« Reply #1 on: October 24, 2007, 10:29:02 am »
I myself prefer 0.9d engine #1.
Tried from d upto o, with enigines 1 and 2. For now d and engine 1 is the winner
Andrey
« Reply #2 on: October 24, 2007, 12:56:10 pm »
Don't let me interrupt your question to the others, but more or less off topic I can say this :
Since Vista is the development path for XXHighEnd I kind of neglected the XP version. More stupidly : what I now use to keep the SQ constant for Engine#3 (hence Vista) just influences SQ from Engine#1 and #2 (both XP and Vista). But :
That it happens like this is just the conclusion from people reporting degraded SQ in #1 and #2, while I actually did not change a bit to the core engines. However, as I learned during time other stuff just influences, which slowly gets under my control. On that matter, I will rebuild the #1 and #2 cores in a fashion that "external" influences do not so anymore, with for now the question how that will turn out for base SQ anyway ... (could be better, could be worse).
For those who were so kind to report differences in a next version on #1 and #2 (like in fact you just did Andrey) :
I am really sorry that I did not do anything about it (described above as "neglected"), because I really did not know what could have caused the difference in subsequent versions accordingly. Mind you, when I started this all well over one year ago, I had explicit means in mind which worked out. During time however, I learned that more things influence than I could have guessed. Also, the more you report these things, and the better you can describe the differences, and withgoing your systems used in your signatures (!), the more I will be able to draw conclusions from all of it.
This really is of the most importance, where engineers et al *know* that SQ can't be influenced by means of (no DSPed) software, or anyway don't have an explanation for it.
I can only emphasize on the fact that "we" are developing this player together, where I myself on my own am unable to listen to all various settings, and of course don't have your systems. I must work with your input, and I *will* do that.
Drawing kind of decent conclusions needs as much input from you as possible. Never hesitate to "complain" !
andy74
« Reply #3 on: October 24, 2007, 02:18:26 pm »
But the way I come to conclusions like one version (player) is better than the other is as follows.
I listen music at work as a background. You can call me grazy but I simply get paranoid when the sound is not right. I experience anxiety attacks. And after an hour of listening to a bad player (and I blame it all on jitter I get in the end) I get an urge to get the phones off my head and runaway.
So I cannot describe it in terms of soundstage, sorry, I just don't have the systems most of you, audiophiles, have.
So the less discomfort I feel the better player is for me. And also I remember how my vinyl records sounded back in 80-90's. I spent so much time listening to it in the evenings before going to sleep and enjoying it very much. So the closer the player to that the better.
About five years ago I started to recollect my music collection I had back then. And of course in mp3 unhappy . Then bought an entry level hi fi system. Played around with interconnects and cables. Realized that cd player is very dependant on the CD print quality while the data on it is the same, and I found out that here is jitter. Then I realized that I need lossless from off PC to my system.
Then my sound card was not the best one. Then not every player sounds good and everything in OS influences the SQ. Then tried Linux with its ALSA and mplayer and xmmplayer and jack. And actually the fact that there are too many variables on the PC made me sad unhappy. But I did not want to return to a CD player.
Then I read somewhere a forum post that somebody (it was you Peter) stripped down linux and ran his own very light player and that irregularities in supplying data to the sound card dac is as important as (results in more) jitter. Then I thought to myself that's a way to go. But did not have time to go there myself.
And now I see that You finally found a way how to overcome all those variables that influence the SQ on the PC side.
Congratulations on that!
The last thing I tried was Slim devices SB3 and it does not compare to 0.9d. BTW I did some blind tests with SB (which I shared to slimdevices forum members) where I could tell flac codec was working inside SB or a pure wav stream was playing. So I think I can hear something even without a great analog tract. I did the tests in my shure 210 earplugs Happy
It was all to show how I tell a better player (to me) form worse.
Thank you
And I hope I did not give you a headache with this post Happy
Gerner
« Reply #4 on: October 24, 2007, 03:08:14 pm »
Peter I cannot agree more, and this forum is a very good proven tool to what you address so sincerely. No-one can make it by him/her-self. In particular when we all of us have so many different pathways to the speaker. And hence you cannot know or gurantee for the SQ of those pathways, then of course this forum is the only handshake between users and developer.
You can conclude from our listed gear if you know each of them and pocessed them. And you can conclude if 70% says yes for this and that version.
And as I know you, you will end up in offering a most flexible player where each one of us can find our preferred settings.
May I shout out loud: BRAVO
The above could govern developping of any audio components wich should address zillions of different listening rooms, amps., sources and bla bla bla.....Only by succesful opinion sharing the developers *football* can come into the goal.
Keep on    clapping
Gerner
Troubleless playback.
« Reply #5 on: October 24, 2007, 03:12:34 pm »
Headache ? oh no ...
Below quote is from one of the first posts I put in this forum : Why XXHighEnd ?
My support activities over at TheaterTek.com allowed me to meet my now good friend Carlos Rodriguez, who just asked me to perform some tests on the Fireface. This was March 2006.
Carlos is able to instantly hear / judge jitter, and via hundreds of emails I started to learn what he actually hears. A dangerous job by itself, because Carlos just can't stand jitter, hence gets crazy of some types of it.
Now what ? Cry Happy
Take it that I know exactly what you mean, although I don't suffer from this myself. But let's say that I know -without you telling it- you can't even watch a movie in the cinema because of this ... innocent
Andrey, from this point on you are a most valuable user to, say, all of us. Of course with this I don't say that other users are not valuabe, but you are able to hear instantly about jitter, where "we" need maybe days to judge the implications of it.
There is no jitter, bad jitter and good jitter. The first must be seen as impossible, the last as what to achieve, where I *take* it, that what is good for you, is good for us just the same. This is no science, so I assume it.
Now let this be off topic : how do you compare Vista with XP on this matter ?
andy74
« Reply #6 on: October 24, 2007, 03:36:05 pm »
Off topic, can't resist:
Movies!!!!!!!!!!! yes you are ABSOLUTELY RIGHT! you made me laugh aloud actually.  biglol
And what is worst of all is our russian doubling of the soundtrack where you don't hear the actors and hear russian doublers ...
Add the bad work of the sound engineer (do not confuse with soundengr Happy). I hardly can wait till the end of the movies. A kind of self punishment I know.
But recently I was in San Diego (Hey Dave! I am going back soon) and watched Bourne Ultimate. It was great. Now I know how good sound can be in movie theatres.
End of offtopic.
Definitely Vista sounds better (in my terms (no paranoid && closer to vinyl Happy )) than XP no matter what player I use.
And of course your player sounds best of all.
So Vista+XXHE is way better than XP+XXHE!
Unfortunately I did not have much time to evaluate it thouroughly. But for now the most difference for my setup was using q1 setting 14 and both priorities Normal. I tried Thread priority set to high but went back to Normal.
Don't want to make conclusions about XX versions on Vista so far.
Andrey
andy74
« Reply #7 on: October 24, 2007, 03:47:48 pm »
One more thing.
I already read your first post about your friend Carlos a week ago. It was another thing proving that I am in the right place.
Thanks
Andrey
andy74
« Reply #8 on: October 29, 2007, 10:42:42 am »
I was listening to 0.9p for 2 days now and compared them with 0.9d and j.
Funny but the 0.9p on XP engine#1 sounds the most "soothing" to me Happy .
I will try couple audiophile terms here: it is easier to follow a particular instrument (I may say more detailed even), while the sound stage got expanded to almost total breakdown into left and right channels.
But the main thing is that I can listen to 0.9p much longer without discomfort. I will stick to it for now.
Did not try it on Vista yet.
Andrey
andy74
« Reply #9 on: November 12, 2007, 11:23:03 pm »
Here I am again talking to myself. Happy
Just to share that 0.9r with its flac and mp3 is great!
The fact that Peter paid a little listen by himself to Engine #1 an 2 did improved the SQ quality. Happy
It IS getiing better!
It is almost like I can't expect more of the SQ anymore Happy. But ready for surprise...
That's the kind of jitter I like!!!
Andrey
« Reply #10 on: November 13, 2007, 11:56:58 am »
I am glad you are happy Andrey.
Maybe I missed it, but did you by now ?
andy74
« Reply #11 on: November 13, 2007, 06:57:09 pm »
I've tried it on Vista.
First expression is: a lot better than XP.
But Actually I haven't got time to do extensive listening to Vista engine #3.
I am now away from Vista PC, and have a laptop with Vista but the sound interface of the laptop is bad.
So that I could not even start engine #3 on Vista. I plan to get myself something decent usb with analog volume control.
And then I will try to evaluate.
But again: even Vista + engine#1,2 sounds better than XP.
Andrey
« Reply #12 on: November 13, 2007, 07:12:08 pm »
My own experience from day before yesterday ... true. Sounds nicely fragile ...
andy74
« Reply #13 on: November 19, 2007, 07:27:25 am »
XP and new versions again.
the version s-0 I could hear that there certain improvements in SQ. but it gave that feeling paranoia again.
That' why I did not liked it.
But s-1 sounds better than s-0 (discomfort wise) in XP for me. First impression it is close to neutral, almost does not have a special signature to say, and does not get in the way between music and listener.
These are my first impressions after comparing s-0 and s-1 on XP.
Andrey
WeHa
« Reply #14 on: November 19, 2007, 08:34:17 am »
Peter, which is better in SQ aspect?
Vista + engine #1 or Vista + engine #2?
thanks.
