November 23, 2024, 08:11:21 am *
Pages: [1] 2 3  All
Author Topic: 9Z-8a and SFS  (Read 39225 times)
« on: December 24, 2012, 10:33:49 pm »
With SFS's below around 12, I get a skipping sound or repeated tick, very soft, with sustained notes. Too early to tell what SFS is "best" here. Other values used are in my signature. Again, thank you, the sound is great.
« Reply #1 on: December 25, 2012, 05:35:12 am »
Is this still so when you kill XXEngine3.exe and retry ?
Can you try to explain to me what you mean with "sustained notes" ? I know what they are in general, but in this context ?
« Reply #2 on: December 26, 2012, 05:21:32 am »
I didn't describe it correctly. It's a constant, soft  clicking sound like a record with one very small scratch. I think it goes away with a SFS of 30 or higher. A SFS of 2 is unlistenable cause it seems to get louder or more intense the lower the SFS. With Z8 the lower SFS's continue to sound better here and, man, the sound is like never before. Talk about shivers with female vocals..........give Eva or the Wailing Jenny's another go.
Peter, hats off to you!
« Reply #3 on: December 26, 2012, 11:31:49 am »
Yep, getting the same 'constant ticks' here with an SFS of 2. Will try killing xxengine3.exe and try higher SFSs too. Have already tried with no PA, and ticks get considerably louder to the point of being unlistenable. With PA-, ticks are really not that bad... but annoying and probably unacceptable in the long run.
« Reply #4 on: December 26, 2012, 11:40:48 am »
They're getting louder and louder with the same setting - so throughout the playing of the track ?
« Reply #5 on: December 26, 2012, 11:48:22 am »
No, ticks remain at the same level, but are louder without PA than with PA-.
Will report back with further investigation.
« Reply #6 on: December 26, 2012, 01:07:34 pm »
Ok, so why don't I have any ticks ? Not with PA(-) and not without PA. With/without Volume Normalization. Q1=14, Q1F=1, DevBufSize = 4096. Driver = 16ms.
With/Without Logging (this may be important because of the huge logging with very low SFS).
So, nothing, let alone unbearable or something.
« Reply #7 on: December 26, 2012, 01:27:14 pm »
I have had those little ticks with Z5 to (SFS 2). Setting SFS to 12 helped. Did not have the time to really play with 9Z-8a.
« Reply #8 on: December 26, 2012, 04:04:04 pm »
I have SFS=2 Q1=14 Q1f=1 and I am getting ticks. They are most noticeable at the end of a track when the music is fading out (but not between tracks) and are a regular pulse at about 100hz. If I listen close to the tweeter they are clearly there all the time a track is playing.
P
« Reply #9 on: December 26, 2012, 04:21:30 pm »
I just changed the USB Buffer size in the XX contol panel from 8 to 16, per Peter's specs, and the ticks, with a SFS of 2, have disappeared, I think....
« Reply #10 on: December 26, 2012, 04:25:58 pm »
Hmm, and let that be the only thing I did not change !
Didn't see the relation ...
Odd. But I will look into it.
« Reply #11 on: December 26, 2012, 04:49:51 pm »
I just changed my USB buffer setting from 4 to 16 and the ticks have also stopped.
« Reply #12 on: December 26, 2012, 05:59:02 pm »
Weird, went outside and brought some wood for the stove down to the backporch for the week. The ticks with a SFS of 2 have returned.......When i went outside I left the system on but not playing.
« Reply #13 on: December 26, 2012, 06:11:26 pm »
Reboot and the ticks are gone. The disappearance, reappearance, and again disappearance with the driver at 16 ms.
« Reply #14 on: December 26, 2012, 08:07:42 pm »
Took another break and the ticks returned. This time, instead of rebooting, i stopped engine 3, hit play and the ticks disappeared.
Pages: [1] 2 3  All
