November 23, 2024, 02:22:08 pm *
Pages: 1 2 [3] 4  All
Author Topic: 9z-8a: Windows 8 pro x64: Kernel Streaming warning message  (Read 39160 times)
phantomax
« Reply #30 on: December 30, 2012, 11:08:27 am »
Hello,
I  have the same problem but with some differences in W7. The sequence after rebooting is:
1 / The slider moves and the clock is running but there is no sound. I didn´t notice it initially because I had the DAC off in early tests.
2 / The Kernel error message appears.
3 / The music plays normally but there are two cases: if I don't press stop after the Kernel message and then press play the slider is forward; if I press stop after the Kernel message the slider is where it should be.
Killing the Engine3 after every stop is working for me to avoid those problems for now.
Maxi
« Reply #31 on: December 30, 2012, 11:16:11 am »
Hi Maxi,
Is your DAC (set to) "Needs 24 bits" ?
Obviously I am looking for the similarities with Alain's problem.
phantomax
« Reply #32 on: December 30, 2012, 11:53:23 am »
I am not in the XXHE partition to check but I think yes.
Maxi
phantomax
« Reply #33 on: December 30, 2012, 12:58:26 pm »
32 bits is ticked in "at > than 16 bits the DAC needs" area.
Maxi
« Reply #34 on: December 30, 2012, 01:16:35 pm »
Thank you Maxi.
Maybe I'm dizzy, but I think I read in the other topic about you using 0.9z-7-5. So is this about 0.9z-8 now ?
phantomax
« Reply #35 on: December 30, 2012, 01:21:58 pm »
Yes. I have not isntalled 0.9z-7-5 at this moment. I had forgotten to change it in my signature.
Maxi
« Reply #36 on: December 30, 2012, 02:55:47 pm »
Alain and Maxi,
I have found a left-over of earlier debugging (which I should have removed and can now be considered a bug), and it can cause your both anomalies. Can you please check whether the below XXEngine3.exe solves your issue ?
Just unzip over your current 0.9z-8 XX folder but first kill XXEngine3.exe from memory.
Let me know the result please.
* XXEngine3-09-z8c00-x.rar (313.96 KB - downloaded 484 times.)
« Reply #37 on: December 30, 2012, 03:30:26 pm »
Will do as soon as electricity is back ... Thanks, Alain
« Reply #38 on: December 30, 2012, 03:35:17 pm »
Played too loud or what ? Happy
phantomax
« Reply #39 on: December 30, 2012, 04:15:31 pm »
Replaced the engine3 with the new one and the next message appears (translated):
"sox.exe - Aplication error
The instruction in 0x00449652 is referred to memory in 0x00294000. Memory could not be read."
There is no music but an intermitent noise.
Replaced the original engine3 and only after several attempts things return to normal.
Maxi
« Reply #40 on: December 30, 2012, 04:22:51 pm »
Well, I'd regard this as coincidental and unrelated. Maybe try it again and when it happens the same have a reboot ?
But I don't see the relation anyway ...
If you're only running 0.9z-8. NOT any z-7 ...
phantomax
« Reply #41 on: December 30, 2012, 04:37:04 pm »
No, there is only one folder with the z8 version. I tried the z7-5 version after the OS was installed in order to activate it and then activate the z8 version but it didn't work (well it worked for Z7-5 but not for Z8) so I went  back to a previous restore point with no XXHE versions at all. Since then only Z8 version was installed.
« Reply #42 on: December 30, 2012, 04:59:40 pm »
Ehm, but did you retry it now ?
Remember, it is not related ...
phantomax
« Reply #43 on: December 30, 2012, 05:00:47 pm »
BINGO! Replaced engine3 with the new one and reboot and everything seems to work OK.
Thank you very much. I hope it works for Alain too.
Maxi
« Reply #44 on: December 30, 2012, 08:05:36 pm »
Haha Happy I wish it would be because if that Wink
