November 23, 2024, 02:18:35 pm *
Pages: 1 [2] 3 4  All
Author Topic: 9z-8a: Windows 8 pro x64: Kernel Streaming warning message  (Read 39159 times)
« Reply #15 on: December 25, 2012, 02:39:20 pm »
Phew. No, I don't think this is normal or that I do anything about this. Seems good a finding !
Notice that with WASAPI I have no problems (started/stopped quite a few times).
Maybe it is related to the Priority settings ? What if you set them all to Normal ?
If that doesn't change, maybe try the Processor Appointment Scheme at "No Appointment" ?
About the log files ... maybe yes. I hope to see what sequence is taken in there. Can you, before you attach them, give them a sequence number 1,2,3,4 as how it chronologically happened ? So, look per type (XX, X3, X3PB) and for each X3 give them that number, the oldest being 1. Which X3 belongs to which X3PB etc. is for me to find out. The XX is important because in there I can see what your actions were (and how X3PB etc. dealt with it).
« Reply #16 on: December 25, 2012, 02:45:00 pm »
I am doing it right now. Should be back in about 20-30 minutes Happy
Thanks again Happy
« Reply #17 on: December 25, 2012, 03:07:10 pm »
With WASAPI XXEngine3 always remains a background process. Tried all various settings which I think can be related, but nothing.
What I do notice (and I saw similar from your log files) is that WASAPI doesn't go to 10ms of ClockResolution anymore (when you ask for 15). So, that's a good thing.
« Reply #18 on: December 25, 2012, 04:03:51 pm »
If I recall correctly, with WASAPI I will get a message if the clock resolution is anything different from 1ms. I just tried it, to finally remember I removed the message from XXHIGHEND folder Wink
And true, with WASAPI, the XXENGINE is consistently staying in the background processes. No error.
Now all is empty (log files erased).
Starting XXHE...
Processor cores = no appointment
PlayerPrio = normal
ThreadPrio = normal
Play = good (xxengine3 in background)
Stop (xxengine3 in BG)
Play = Error (xxengine in foreground)
First logs sent (except for the "general" log)
EDIT: to have the possibility of copying the X3PB, I had to press Play again and get the error, since xxengine3 ceased its hold of the X3PB file...
* X3-20121225-095240.log (3.5 KB - downloaded 486 times.)
* X3PB-20121225-095240.log (1.13 KB - downloaded 500 times.)
« Reply #19 on: December 25, 2012, 04:14:40 pm »
What about a foreground process being something with a screen ? So, when the error message is on-screen it will become a foreground process ?
« Reply #20 on: December 25, 2012, 04:29:20 pm »
This one goes with the previous files and completes the cycle: Play - Stop - Play *ERROR*.
It alternates...
* X3PB-20121225-095539.log (0.72 KB - downloaded 483 times.)
« Reply #21 on: December 25, 2012, 04:32:40 pm »
Exactly... I leave the process manager open, so as soon as the error appears, I see the xxengine disappears from background and appear in foreground processes... Windows 8 is quite interesting with its new display by groups (foreground aka "applications", background, then Windows processes)...
« Reply #22 on: December 25, 2012, 04:37:15 pm »
Hey, an error shows in that last log file ! aha ...
But what I wanted to say anyway ... did you try this all in W7 ? I think it can happen just the same in there ...
Is it easy for you to try ? (or maybe you did already)
« Reply #23 on: December 25, 2012, 04:49:40 pm »
When I decided to go the W8 route, it was with the awareness that I would (or should) not go back to W7 for the music PC. I do have a backup of W7 if you want me to test it ?
« Reply #24 on: December 25, 2012, 05:16:42 pm »
Want you to test it ... hmm ...
Point is, I have the hunch that you'll have the same problem in W7 and this hunch is given by the changes I applied in the area. And your log file adds to the thinking that it possibly isn't a W8 problem. This is crucial to me, because I would be looking for something which doesn't exist if it's in W7 just the same.
In the mean time I do not see how I will have soon solved the MinOS problem. If every attempt takes a small hour to get back to the normal situation ... So I'd say W8 is quite unusable at this moment anyway, assumed MinOS brings the far better sound.
Besides, I really must think and see what actually happens, because to me it looks mighty strange that booting into safe mode gives the exact situation (no desktop as it looks). It is just unmanagable this way, and I don't have the illusion that I will find anything about THIS in Google. Haha. But not-haha because where to go from here ? As I said, unmanagable.
Ok, done with this sh*t for now.
Maybe this nice "refresh" makes the install of the NOS1 driver work. Because that too I can't understand (works on W8 Consumer Preview).
Bweh
« Reply #25 on: December 25, 2012, 05:24:26 pm »
Maybe we should profit of what is working and from what I read from the others, I am missing a lot by being stubborn with Windows 8.
Not to forget that today is Christmas ! Happy I will go see my family Happy
I don't have any problem reverting to Windows 7 because I got a backup. I will be doing it in the following minutes.
I will even ask to get an activation key for my laptop (that I haven't used for a while). I got a Audioquest Dragonfly recently and I am really curious to hear it with XXHIGHEND on my laptop... Meybe I will convince someone of the merits of  XXHIGHEND ?
Hey Happy Merry Christmas !
« Reply #26 on: December 25, 2012, 05:29:14 pm »
Ok Alain. Take your time with it.
It's starting to be boozing - and dinner prep time here.
Thanks for your help and remember that you finally brought forward that error, wich is important. Merry Christmas to you too and enjoy the family !
« Reply #27 on: December 25, 2012, 06:53:52 pm »
Just before I leave Happy Yes, the same message appears with Windows 7. How did you know ? Wink
Ok, now I leave Happy
« Reply #28 on: December 25, 2012, 07:11:28 pm »
Hey, super !
But a small reminder (but for fun of course) : it is you yourself who created all these "restart" problems with your little pitch problem. So, apparently I *again* did something wrong in this department (the solution for you created problems for others and to solve that now you have another problem again).
But really, great to know where I must look for now.
Great thanks and sorry for the inconvenience,
« Reply #29 on: December 25, 2012, 08:46:23 pm »
Hey, super !
No inconvenience at all Happy Your accomplishments brings light in my present. And nothing happens to someone that does nothing Happy
Page created in 0.081 seconds with 19 queries.
