November 23, 2024, 02:06:23 pm *
Pages: [1] 2 3 4  All
Author Topic: 9z-8a: Windows 8 pro x64: Kernel Streaming warning message  (Read 39158 times)
« on: December 24, 2012, 08:58:37 pm »
This message appears now when I play a song. I have first to press "OK" to have it disappear, then I press Play again and it's ok.
I checked the settings and all is ok. My DAC needs 24 bit and plays up to 24/192. Nothing unusual.
Ah, there is also something that happens whenever I press "S" for the settings. A black box (like a cmd.exe box) appears briefly before the Settings appear (?)...
« Reply #1 on: December 24, 2012, 09:05:35 pm »
Hey Alain,
Can you provide me the X3 and X3PB log files when this error message is on the screen (not later) ?
If you mean that you press "S" when the Settings are on-screen, that could be correct but is not intended anyway. Is this the case ?
When not, you might hand me the XX log file of *that*, and please right after the happening.
« Reply #2 on: December 24, 2012, 09:24:16 pm »
Hey Alain,
I have included the 2 files as requested for the first situation (the warning message).
As for this screen thing that briefly appears, I am not sure
* X3-20121224-151125.log (5.54 KB - downloaded 488 times.)
* X3PB-20121224-151125.log (1.13 KB - downloaded 492 times.)
« Reply #3 on: December 24, 2012, 09:39:15 pm »
Oops... I posted too fast...
For the second behaviour: a black screen opens (it does not take the full screen, it really looks like a cmd screen is opened and I can briefly see "C:\XXHIGHEND", that correspond to the folder where XXHIGHEND is...
Hope all is ok...
Thanks Happy
* X3-20121224-152316.log (12.66 KB - downloaded 490 times.)
* X3PB-20121224-152359.log (0.98 KB - downloaded 486 times.)
« Reply #4 on: December 24, 2012, 09:48:50 pm »
About your last post Alain ... that needs the XX log files (not X3 or X3PB). But I have those too now, just in case. grazy
« Reply #5 on: December 24, 2012, 10:01:17 pm »
Does this message pop up during playback or something ? It really doesn't look like this is before any sound was heard.
If you are not sure, please look at the times in the X3 vs X3PB log files. They should start with about the same times. These do not and what I'm looking for is lacking. But it really looks strange !
This is Engine#4, right ?
Ok, what about killing XXEngine3.exe before a next attempt for the log files ?
Sorry for the inconvenience !
« Reply #6 on: December 24, 2012, 10:15:48 pm »
I will do as soon as possible. I am preparing to leave for Christmas Eve and I will get killed by my sweetheart if I stay in front of my PC...
I can tell that this message pops when I press Play. Nothing happens, then I see the Warning appears. In fact, I'd better say "Error" instead. After I press OK, the music does not start. Then if I press Play again, the music starts...
« Reply #7 on: December 25, 2012, 12:38:00 pm »
No worries. I should be able to test this myself. Well, hopefully - if I can find a Mobo sound device which allows for Kernel Streaming.
« Reply #8 on: December 25, 2012, 01:23:34 pm »
I finally was able to make sense out of your 4 log files posted. But nothing is in there that leads me to an error message; You will have had some (like you showed), but it is not logged.
I am tempted to ask : Is this repeatable ?
I mean, I have it sometimes as well (without recognizable reason).
You may try to tell me the sequence of happenings when you start out with XXEngine3.exe not in memory. For example :
- Killed sound engine;
- Play;
- Error message abc;
- Click away message;
- Play [plays];
- Stop;
- Play [plays].
- Play;
Such a sequence would indicate that the message happens one time only each time when the sound engine is started.
Btw, I do not have KS device in my W8 machine so I can't test it. Engine#3 (WASAPI) runs fine (ehm, no amps or anything connected).
Right now I am stuck on this one, so I hope you can help ...
« Reply #9 on: December 25, 2012, 01:39:25 pm »
Merry Christmas ! Happy
First about the "MS-DOS" window that briefly appears: I started XXHE without playing anything and I selected "S" to go to the settings... This is the XX log file I think you asked for ?
* XX-20121225-072525.log (2.24 KB - downloaded 486 times.)
« Reply #10 on: December 25, 2012, 02:03:41 pm »
- Play;
- Play [plays];
- Stop;
- Play [plays].
- Play;
Ok...
- Rebooted the system
- the song is already in the playlist
- Play = good
- Stop
- Play (the same song) = Error message
- Press OK, then Play again = good
- Stop
- Kill XXENGINE
- Play = good
- Stop
- Play = Error message
- OK
- Play = good...
There are lots of files, would you like them all ?
« Reply #11 on: December 25, 2012, 02:13:23 pm »
That could be convenient, yes. But only those from the last sequence should suffice.
Hey thanks.
« Reply #12 on: December 25, 2012, 02:22:43 pm »
Stupid me ...
So, aha, *that* [ S ] ! I thought you talked about Stop. But clearly I didn't read well.
Ok, so that is perfectly normal. It flickers, but that seems unavoidable. So yes, there's a Dos call there.
All right, this one is solved.
« Reply #13 on: December 25, 2012, 02:23:38 pm »
Is XXENGINE a "background" process normally ?
The first time I press Play and all works, the XXENGINE appears in the "background" processes.
Stop - still in "background" processes
Play - Error message, then XXENGINE appears in "application" processes
I press OK, then XXENGINE disappears
I press Play, XXENGINE starts in "background" processes...
Et all...
« Reply #14 on: December 25, 2012, 02:31:53 pm »
Hey thanks.
Sorry Peter, I did not see this post... After this "background" then "foreground" permutation, would you still like to have the log files ?...
