November 23, 2024, 01:59:42 am *
Pages: 1 2 [3]  All
Author Topic: Watch your stockings - 0.9z-8  (Read 34907 times)
stefanobilliani
« Reply #30 on: December 25, 2012, 01:07:52 am »
It is also all functioning very well with my system .
It also activated ok , Minimized ok ( incredible , I was waiting for that ) .
Fantastic software and the Xtweaks are just wonderful . In my system going to time performance index = obtimal , makes quite a big difference to the music .
Very very good .
Thanks and regards
Stefano
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
Jud
« Reply #31 on: December 25, 2012, 04:50:36 am »
I agree with others' impressions of the sound, *but*: Seems to me I hear the slightest "sizzle" in the upper midrange, and slightest "fuzz" in the lower midrange that was not there before.  Switched to my IEMs just to be sure it wasn't in the speakers or amp.
By the way - it's not impossible my, ehm, cheap preamp is responsible and I'm just now getting audio response that will tickle the bug, or clarity sufficient to hear it.  My computer I would consider less probable.
Right, so of course on further experimentation it turns out to be my computer under the XTweaks settings.  The most critical one for me seems to be Cool When Idle.  If that's set to off, no balanced load setting sounds quite correct, lower ones having too little liveliness and higher ones having too much sizzle, with no happy medium.  Turning all the XTweaks off leaves things with the sound of -7, very nice but not up to -8.  If Cool When Idle is on, then a Balanced Load setting of 70 sounds about right on the liveliness scale - things "swing" nicely - without having the unacceptable level of sizzle that occurs if Cool When Idle is off at that load setting.  There is still just a very slightly perceptible edge, but since I can't seem to get rid of it entirely without turning off all the XTweaks and losing all the accompanying sonic benefits, this last little bit is acceptable to me right now.
With Cool When Idle on and Balanced Load at 70, the Stable Power setting doesn't make a huge difference, the Utilize Cores Always a bit more but still not a lot - both do sound slightly better when on, though, so that's where I have them.
« Reply #32 on: December 25, 2012, 07:04:01 am »
Thanks Saint Peter Nicholas Happy
I grabbed it about 3am local time before nodding off to sleep but didn't open it up. A quick check now revealed the elves forgot a magic widget and it had to be re-wrapped, but I've got it now and will have a play shortly, and report findings over next few days, in between cricket watching !
Seasons greetings to all, and go easy on the chrissie pudding Wink
henri21961
« Reply #33 on: December 26, 2012, 02:42:11 pm »
I happy everthing works well, I have also a jplay player for jriver for this moment for my wife,  youre player I just keep for my self begause it's the best in space and more micro information, just more music!!!!!!
I only  play on  special mode  with a firewire connection. and everthing minium.
« Reply #34 on: December 26, 2012, 02:43:44 pm »
Thank you Henri. Very nice to hear !
Pages: 1 2 [3]  All
