« on: December 24, 2012, 12:17:17 pm » |
For a few around the globe Christmas Eve already started. To those : watch your stockings tomorrow morning. For others : watch your Christmas Trees.
In any event, reserve some heavy time for your next heavy tweaking when 0.9z-8 is up in 5 hours or so from now. Be prepared to not see your beds.
End-of-message
« Reply #1 on: December 24, 2012, 12:40:29 pm » |
Well fortunately I'm away from home so won't have my Christmas interrupted by XX tweaking. But looking forward to playing with 0.9z-8 soon.
Thanks for all the developments this year Peter. Keep 'em coming!
Jud
« Reply #2 on: December 24, 2012, 01:35:25 pm » |
My second-favorite toy!
Win 7 64-bit; i7-950@3.07GHz; 16GB RAM; OS on SATA 6GB/s SSD; AIFF files on external FW HDD; XXHE and Playback Drive on separate RAMdisks; no page file; Audioquest Dragonfly DAC/preamp; PSE Studio IV amp; Pioneer SP-BS22-LR bookshelf speakers or Etymotic Research ER-4P in-ear monitors. XXHE 0.9z-8-3a settings for the moment: Peak Extend; Arc Prediction; Redbook files upsampled 2x; KS Adaptive Mode; Phase Alignment off; buffer=512; Straight Contiguous; Playerprio=Low; ThreadPrio=RealTime; Unattended; OS minimized; all services off; Q1=17, factor=2; SFS=2.1; XXTweaks=Ultimate; Time Performance Index=Not the best.
Eric
« Reply #3 on: December 24, 2012, 01:45:11 pm » |
Can't wait for it! What is the main feature of 0.9z-8 Peter? Or is it more like a collection of various things?
Cheers, Eric
3.2GHz CPU, 8GB RAM, XXHE 1.186a, W7x64 SP1 Ultimate on 2.5" 10Krpm SATAII spinning disk, 8GB RAM / KS:Phasure NOS1 Out 4.0 / #4 Engine / Adaptive / Buffer 4096 / ClockRes 1ms/ Stop All Services / Monitor Off / SFS = 0.4 / not Invert / No XTweaks / Playback Drive = External USB3 (USB powered) HDD / Unattended/ Minimize OS / Peak Ext / ArcPredict / PA- / Q1,-,3,4,5=14,-,0,0,0 Control Panel: Sample Rate: 352.800kHz/ USB Buffer Size: 8ms Amps: BD-Design bridged Gainclones
« Reply #4 on: December 24, 2012, 01:52:47 pm » |
Peter, Thanks for everything you have done, not only this year, but all these years. Music is good for the soul and you have certainly contributed to motivate us with this wonderful hobby Regards, Alain
« Reply #5 on: December 24, 2012, 04:07:27 pm » |
In any event, reserve some heavy time for your next heavy tweaking when 0.9z-8 is up in 5 hours or so from now. Be prepared to not see your beds. 9z-8? What happened to .6 and .7? ;-) That big improvement? Can't wait! Bert Merry Christmas!
« Reply #6 on: December 24, 2012, 04:10:24 pm » |
I know, it is difficult with all these numbers. Ok, small advice : better skip 0.9z-8 !
« Reply #7 on: December 24, 2012, 04:25:37 pm » |
Anyway ... If you all look under your tree now ... there is presentssss Don't try to open them all together. That might be messy, slow, bits run through eachother et cetera. Not good. So, nicely wait for your turn now. Hmm ...
« Reply #8 on: December 24, 2012, 04:29:14 pm » |
Oh, I am excited myself as never before. You may take my settings as a lead. BUT, there's a number 85 in there. Change that to 65 at first (or early fireworks may be your part).
Have fun, a turkey and JINGLE THOSE BELLS ! Peter
« Reply #9 on: December 24, 2012, 05:04:06 pm » |
Thanks Peter! Good timing, I needed a bigger present under the tree then what I bought for myself. I can't wait for the family to leave, will be late today! Best wishes for all.
« Reply #10 on: December 24, 2012, 05:31:56 pm » |
I can't make it work... back to 9z-75 (see error).
The popup window normally showing what I should do during the install does not show, the error mesage comes instead.
Followed the Release Notes. Should I uninstall other things first or is this out of my hands?
Hopefully other people have more luck.
« Reply #11 on: December 24, 2012, 05:59:10 pm » |
Mmmm... I have the same problem... Same screen (in French though). Can't make it work...
« Reply #12 on: December 24, 2012, 06:09:42 pm » |
Ok, quick question to others : is someone NOT seeing this problem ?
It should just work ...
Alain, is this the same message/error you talked about via PM ? Notice that Bert's error tells that this happens when the Settings Area is selected. Edit ... which is not really what Bert says. Hmm ...
« Reply #13 on: December 24, 2012, 06:17:57 pm » |
I can mimic it. Ok, a bit of a bad timing, but I am trying to solve it ...
« Reply #14 on: December 24, 2012, 06:32:16 pm » |
Peter, No, the one mentionned in PM was happening before. I just thought it would be OK to ask first if you encountered somehing like that while testing with W8... Alain
