April 17, 2025, 10:43:25 am *
Author Topic: Post Mortem Sound System-This is definitely going a bit too far, don't ya think?  (Read 7720 times)
« on: December 12, 2012, 12:25:34 pm »
http://www.philly.com/philly/entertainment/They_make_coffins_with_sound_systems_so_you_can_jam_out_after_you_die.html
listening
« Reply #1 on: December 12, 2012, 12:52:41 pm »
But maybe the smaller "housemates" are enjoying this  scratching
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #2 on: December 12, 2012, 03:16:34 pm »
I was wondering ... does that come with a USB connection ? I mean, then we can connect an external DAC, right ? swoon
« Reply #3 on: December 12, 2012, 04:08:25 pm »
It's hard enough getting the SQ right when you're alive. I wouldn't want to be rolling in the grave... or should that be rock 'n' rolling in the grave?
Page created in 9.431 seconds with 19 queries.
