November 23, 2024, 06:06:57 am *
Author Topic: 09z-7-5: only one track playing in attended mode for 24 bits 96khz material  (Read 4746 times)
« on: December 09, 2012, 08:57:20 pm »
When i load the playlist with complete album it only play's one track in attended mode. After that i see a sample rate message ' failed to set sample rate' and a second message 'engine #4 did not start within the expected time'. I have this problem with 24 bits 96 khz material. Is this a known error? In a second test with another(24 bits 96khz) album starting with the fourth track same effects. In unattended mode all works ok.
Regards johan
« Reply #1 on: December 09, 2012, 10:41:01 pm »
Hi Johan,
Don't you get a message in advance than not more that one track will play in Attended Mode ? You actualy should. Well, with the Q1 x Q1F x DeviceBufferSize being too high.
Try to lower that and retry.
And let me know whether it helps please ... and what the difference is with the settings not working ...
