November 23, 2024, 03:25:20 pm *
Author Topic: 0.9z-7-4: My most annoying problems #1 - Song Length Calculation  (Read 18971 times)
charliemb
« on: November 14, 2012, 01:53:54 am »
In attended mode  (not UNattended)
Calculation of song length is OFTEN much longer than actual.
This results in a song ending and then going into silence as I watch the progress slider move to the right for a couple of minutes until it reaches the end.
This happens with AIF, FLAC, high res, and low res too.   I have very few WAV files.  [Editorial: this problems seem to be related to a rate change with fx on.  Maybe.]
[the next problem I will report on #2 of 2 is tied to recovering from this problem, also attended.]
[Please don't ask why I'm using attended mode.  To make a long story short, it sounds better than 7-4 and gets around UNattended problems that I've not reported yet]
« Last Edit: November 14, 2012, 08:23:18 am by PeterSt » Logged
July 2019:
« Reply #1 on: November 14, 2012, 08:23:03 am »
Although MAYBE I could make this more decent, it is you
yourself doing this. Well, I'm fairly confident about that. So, it is officially allowed to click on another track than the one which is playing, and once you are going to do such things, you will activate the time for that other track.
But this is not all what's involved ...
That other track can also be of another format, and now things get nasty.
Clear solution : Don't allow clicking on these other tracks while playing. However :
That this is allowed is explicit and for a reason (I don't know anymore).
I'm afraid this is as it is, but it will be you encouraging for it.
It will be true that this is related to your other 2 problems as well.
« Reply #2 on: November 14, 2012, 05:34:31 pm »
Charlie,
I was just thinking ...
I would have been more simple (and less "aggressive" (though well meant) from my side) to ask you for a clear situation when you receive this anomaly. So, you sure will be able to do this, but then I can more to the point lay out what you should have done "better" OR I would have learned in what very normal (for usage) situation this goes odd.
So, if possible a step my step guide for me to mimic such a situation. Ok ?
charliemb
« Reply #3 on: November 15, 2012, 01:47:19 am »
No,  I'm not doing that (clicking on another track).
July 2019:
charliemb
« Reply #4 on: November 15, 2012, 01:59:58 am »
... then I can more to the point lay out what you should have done "better" OR I would have learned in what very normal (for usage) situation this goes odd.
I apologize for not giving a more detailed explanation before.
To recreate the problem, do this:
  • Work entirely in Attended Mode
  • Clear your playlist.  Make sure fx is turned on etc.
  • Go to your Nice Stuff directory.
  • Select a good number of albums and make sure you select some with mixed resolutions and sample rates.
  • Right click and choose random play.  This should create a long playlist.
  • Now play the list and be prepared to realize that something is not working like it should.
At no time should you click on any other track.
If that alone does not recreate the problem, then try this:  Stop playback.  Select a track somewhere in the middle of the long playlist.  Start to play it.  You should soon see a problem.  This simulates restarting the list from where you left off the day before.
July 2019:
charliemb
« Reply #5 on: November 15, 2012, 03:06:41 am »
Just now I tried letting it run.  Just hit play and never again touch the mouse.  Everything played okay until: 5 songs into the list, a 96KHz 24 bit, 1 minute track.  xxHE erroneously calculated it as a 2 minute song.  Song ended after 1 minute of play.   xxHE Kept playing silence until the end of the erroneously calculated 2 minutes.  Then the track progress indicator stopped at the end and nothing for about 30 seconds more.   Then the following error messages poped up in succession:
Error window 1: Audio device could not be determined
Error window 2: Engine #4 did not start in the expected time
Error window 3: Windows OS error saying xxEngine3 stopped working
July 2019:
« Reply #6 on: November 15, 2012, 08:54:06 am »
Charlie,
Without looking into it yet, I'm afraid that this all was introduced with 0.9z-7. Maybe even a version into that. So, I tried to solve "length" issues from HDTracks files and I'm fairly sure this can cause problems elsewhere. Testing it all is undoable.
I even recall a change in 0.9z-7-5 itself ...
IOW Charlie, while I was pretty firm in my "hey this all works", I forgot about these changes. So I must apologise ...
That being said, can you please be more specific about
a. those Hires files (origin);
b. your playback means (all I see in your sig is No Arc Prediction).
And do you actually say that with Unattended you don't see the problem ? (I ask this because you are the first reporting about this and *if* Unattended doesn't give the problem it could be more easy for me to find the solution). If it is more difficult for you to test this, that's fine.
Can you recognize that in earlier versions this wasn't a problem ? (the answer to this is crucial)
Thanks ...
charliemb
« Reply #7 on: November 15, 2012, 02:02:04 pm »
Thanks ...
a. At least one of the HiRes files is an HDtracks:  Paul McCartney _Band on the Run_ the uncompressed version.  I believe it is 96KHz.  And it had errors.  Others may be from non-HDtracks, I will have to check.  (Not to stick it in your eye but JRiver  has no problems with any HiRes material of any kind in my collection).
b. 2x upsampling with no method selected (repeat bits).  fx usually on, but last night I tried fx off and the problem still occurs (the only difference is that high res files play at 88 or 96 with fx on, and at 176 or 192 with fx off).  Of the two options listed in my sig, I'm using adaptive right now, with 15ms requested).
Correct, generally I do not see this problem in UNattended.  Instead, I have another problem I have reported in the past, better, but not totally fixed; namely, the high res tracks sometimes stop playing short of the actual length, but at least it moves on to the next track.
Correct again, in version 6, I was not having this problem.  Instead, it did not allow format changes at all.  So playback would stop.  I'd start it manually.   That was better.  And as I recall, version 5 allowed format changes with fx on, and that worked mostly okay I think (it was a long time ago) but was not perfect.
However, this problem of Attended (not unattended) also happens with low res.  However, I think low res plays fine until it first encounters a problem with high res.  After that, both can miscalculate.
Another hint: If I load that same McCartney album all by itself, I believe 99.9% that it will play Attended with no problems.
Another hint: The track times shown in the mixed playlist is wrong, they are too long to begin with.  So I think the bug is in the pre-calculation of the song length from the start, and perhaps only in mixed playlist mode, maybe even only in long mixed playlists.  Once these are miscalculated, it makes sense that the player would play them the way they are played with long gaps of silence.   (But this does not explain the error messages if left alone.)
July 2019:
« Reply #8 on: November 15, 2012, 06:18:33 pm »
Thank you Charlie.
So for now you can deactivate Allow Format Change and it would be "better". Right ?
I will solve it !
charliemb
« Reply #9 on: November 16, 2012, 02:08:34 am »
I will solve it !
Actually, I didn't think of that.  I'll try it.   Grumble grumbe...  for now.  naughty
July 2019:
charliemb
« Reply #10 on: November 16, 2012, 02:48:27 pm »
I will solve it !
Disabling Allow Format Change had mixed results last night.  In the repeated failure, almost the same things happened: Got the cannot allocate audio device message, and then afterwards trying to start the next track manually met with the same non-playback, even after hitting the Play button several times.   Hitting stop and Play repeatedly got it going again.
So not much help.   But I do think that one high res track played correctly, and with the correct time. t think of that.
[note: my sig has been updated]
July 2019:
charliemb
« Reply #11 on: November 17, 2012, 08:38:45 pm »
A few new hints for this problem"
1) What do you suppose unchecking Allow Format Change did to this song length calculation problem?
Answer:  Very few length miscalculations.   But I still have to manually deal with all of the other problems (errors messages, Next does not work,  clicking on Play does not work usually,  sometimes clicking Play two or three times starts to play finally, and sometimes nothing short of killing engine #3 and exiting xx and restarting allows me to continue.   But few length miscalculations.
2) What do you suppose dropping SFS from 60 down to 8, 20, or 30 did?
Answer: It often works, not always.  This means, even checking Allow Format Change sort of works, not fully.  In a short amount of time, a 44.1/16 flac file had the wrong length and I let it play through the silence until the end (about 1min) and it kept playing.  This is no solution because the sound is not nearly as good at these lower SFS levels and clicking happens every now and then, which never happened before in xx for me.
Thanks Peter
[BTW, I vote for the behavior or PE *OFF* as implemented in 0.9z-7-4]
July 2019:
« Reply #12 on: November 18, 2012, 10:08:11 am »
Charlie, point is : I expected the whole thing to happen in OK fashion with Allow Format Change being Off. But apparently that doesn't matter. But it also should imply that pressing stop on the one track, clicking the next and press play won't help just the same. And I think you already said a kind of like that.
But let's not be speculative anymore (my side) because I must look into it which I did not do yet.
charliemb
« Reply #13 on: November 18, 2012, 04:13:32 pm »
... But it also should imply that pressing stop on the one track, clicking the next and press play won't help just the same. ...
That's correct.  It doesn't help much.  Helps sometimes, but even then, I have to repeatedly hit Play to get it to start (even though the red Play LED light indicates that it is attempting to play from the first manual click).  Other times, exiting Engine3 and xxHE and restarting is the only way to proceed.
July 2019:
« Reply #14 on: November 18, 2012, 04:23:03 pm »
Well, FYI : It it is worse. Of course we are at 0.9z-7-5 already, but that one doesn't allow any format change at all (again). So I haven't even started to mimic your behavior.
And strangely enough, *after* 7-5 I again applied changes (HDCD related) and that worked. But actually nothing works.
Point seems to be indeed that sometimes it does work. And repeatedly. But do something else in between and for the life of me I can't get it going anymore. This must be what you are experiencing ...
(no further help needed - yea, a shrink !)
Page created in 0.104 seconds with 19 queries.
