November 22, 2024, 11:47:40 pm *
Author Topic: Forgot to bring back Min OS...  (Read 26070 times)
« Reply #15 on: November 08, 2012, 11:11:54 am »
Any fresh idea?
Try to start from square one and delete XXH at first.
A) Go to Systemmanagement and uninstall via "Programme/Programm deinstallieren" the Phasure OCX program
B) reboot the PC
C) perform now a fresh installation of XXH, and during that process the "Phasure OCX" files will be installed again.
D) and then follow the normal procedure.
This works an my PC.
Best
« Reply #16 on: November 09, 2012, 09:29:12 am »
Problem solved.
I will now think of a way to emphasize even more the importance of following the sequence 100% as sent by email, because it really happens more often that because of not doing so one won't get there.
Joachim, thanks for your help here.
The problem of course originates with me (the awkward procedure). I'll just admit it ...
CaOd
« Reply #17 on: November 09, 2012, 11:05:35 pm »
Just a quick "Thank you" to all who have helped here.
By chance, activation worked out the first time not following precisely the description given by Peter, the 2nd time I failed by doing at again "so so", and messed it up.
Solved now by following exactly the advice given in Peter´s email. Great help to talk to people who understand what is going on here, I would otherwise have ended up reinstalling Win7 (nightmare with boocamp on a Mac to get all drivers properly running and shutting down what is not needed (like battery management!) for low latency).
Have learned a lot this week. Desperately needed my system for a comparison with Amarra on the same DAC (Weiss 202 tuned by Klang und Kunst). Will report here if you like. Have yet to listen to your NOS DAC, once I am back in Germany (currently I live in Lisbon) I will try to get i touch with a fellow running XX with NOS Dac, my system is portable, so would be fun to listen.
Thanks again for all the knowledgable help!
Best Carsten
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #18 on: November 13, 2012, 06:40:09 am »
It would be interesting to know how one can actually determine if  the OS has minimised, other than the red led on the Min OS button.
praphan
« Reply #19 on: November 13, 2012, 07:29:50 am »
1. Check the authenticity of Window licence. Go to Window activation page by clicking Start , right clicking Computer, clicking Properties. At the lower pane, the system will tell you that your Window is not activated or illegal version.
2. Try using some W7 tools say Disk Management. Click Start, Search Disk Management in the search box. You will not be able to launch this tool.
Hope this help.
« Reply #20 on: November 19, 2012, 12:28:17 pm »
Hope this help.
Hi Praphan,
If these are the indication to determine if the OS is Min, then in my case it is certainly not minimised inspite of the LED being red. How do I get it to min?
« Reply #21 on: November 19, 2012, 02:43:04 pm »
Arvind,
If the button is red at this moment, use it to boot into Normal Mode. After that, reboot three times in normal fashion (StartButton - Restart etc.).
Then use the (now blue) button in XXHighEnd again.
Didn't help ? then you too (like I just told in the other topic) can send be an email which explains to me how you can tell that you are Activated properly. And from there we will proceed.
« Reply #22 on: November 20, 2012, 06:55:04 am »
Arvind,
If I understand you correctly, I am on red now, I click it to normal mode (blue LED), reboot the PC three times, click on min OS convert it to red & reboot again. Then check if I am actually on Min mode.
« Reply #23 on: November 20, 2012, 08:03:29 am »
That is correct Arvind.
I'm afraid it won't help, but it is worth a try. If it doesn't help, don't forget to send me this email.
praphan
« Reply #24 on: November 20, 2012, 10:37:26 am »
Hi Arvind,
You are most likely having problem with activation of this XXHE version. In this case, Peter will usually help each individual situation by email.
Praphan
« Reply #25 on: November 20, 2012, 03:17:30 pm »
It worked out, now I am on min OS. Thanks.
« Reply #26 on: November 20, 2012, 03:41:04 pm »
Hi Arvind, that is great.
But do you mean that my presented procedure actually worked ?
« Reply #27 on: November 20, 2012, 04:45:09 pm »
Oh yes the 3 times rebooting worked fine.
Page created in 0.143 seconds with 19 queries.
