November 22, 2024, 06:56:29 pm *
Author Topic: Forgot to bring back Min OS...  (Read 26050 times)
CaOd
« on: November 05, 2012, 11:47:20 pm »
somehow my 09z74 got screwed up (I messed up with Galleries or presets or whatsoever), I deleted all XX files to make a fresh install of 09z75, but why the f... ever forgot to bring back the OS to a normal state. So I installed 09z75 with the OS still being minimized. Unfortunately, I do not have a restore point for the OS (sh...)
What to do now?
09z75 seems to run ok, is activated, but Min OS does not change to active (red). Stays blue after rebooting. unhappy
Any help for a desperate fellow???
Thanks Carsten
August 26, 2013 (0.9z-9b)
MacBookPro 15" i7 2,4Ghz,16GB,Win 8 Pro 64bits, OS on internal SSD, XXHE on internal SSD, Music (WAV) on spinning disc, loaded on Ramdrive,
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 15/0/0/0/5 / Q1Factor = 10 (Dev.Buffer = 256) / ClockRes = 1ms / Straight Contiguous / PA off / SFS = 120 / not Invert / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 / UnAttended (Just Start) / All Services Off /XTweaks : Balanced Load = 45 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / Minimize OS = On / 4 times Arc Prediction Upsampling  -> Weiss DAC202 (modified by Klang&Kunst) -> Jadis DA50Signature -> Audioplan Kontrast V
« Reply #1 on: November 06, 2012, 09:38:37 am »
Rightclick the word "Minimise OS" under the button.
Follow the popup.
Regards, Coen
« Reply #2 on: November 06, 2012, 09:57:54 am »
Hi Carsten,
I hope Coen's advice will help you (I am not so sure myself). But if not, you will let it know, right ? Happy
CaOd
« Reply #3 on: November 06, 2012, 04:36:26 pm »
Hi Coen, Peter,
thanks for your help, I toggeled the MinOS button to red, but when I hit it and reboot, it will come back up as red, so whatever I do, the status indicated by XX stays the same (When I toggle to blue and reboot a couple of times, it stays blue, when I toggle to red and reboot a couple of times, it stays red)
How can I tell from Windows settings (Control panel?) that I am in the non minimized OS mode? Any chance?
Some more strange things I have observed: I gues I am activated, since I can choose memory allocation schemes, but when the Coverart comes up at unattended pla, it still shows a pale yellowish rendering, not the red-orange one that I am used to (and take as a signal for activation, right?).
Second, PA does not engage, it keeps the ~ sign instead of the *.
Would it help to do a fresh install of XX if I could indentify a normal OS status?
Thanks (from an almost desperate)
Carsten
« Reply #4 on: November 06, 2012, 04:58:23 pm »
Carsten, on my system minimized mode is indicated when the "loudspeaker icon" in the lower right hand taskbar has a red "X" over it. When there is no "X" I'm in full OS mode.
« Reply #5 on: November 06, 2012, 08:40:46 pm »
I found the crossed loudspeaker not a reliable indicator.
Well, for something completely different:
You can also try to start the discmanager. Type "format" in the searchbar (startmenu) and select the discmanager. In minimised OS it will give an error that the "virtual disc service" is not available.
I hope that gives a clue.
Regards, Coen
CaOd
« Reply #6 on: November 06, 2012, 09:52:10 pm »
Thanks boleary and Coen,
if the the discmanager is a reliable indicator, then I am always in minimized OS mode, whatever I try and do.
Does it mean I have to do a full reinstall of the system?
Or is there any chance to get it back (manually perhaps)?
Thanks Carsten
« Reply #7 on: November 06, 2012, 11:48:13 pm »
I had a similar problem before.
You have to install the release 09z74 again, unminimize with this release the OS,
and then install 09z75, activate it + minimize OS.
This procedure was working on my system.
« Reply #8 on: November 07, 2012, 08:25:55 am »
And when you are in normal mode again the automatic restore points should be seen again than too.
« Reply #9 on: November 07, 2012, 09:32:27 am »
Carsten,
Before you suggested it yourself, the first part of your last post indeed indicates that you lost your Activation. So, that really is it.
If re-entering your last received Code for Activation doesn't do the job (but follow the procedure in well-fashion), then don't fuss around too much and better obtain a new one. Money will be sent back of course.
CaOd
« Reply #10 on: November 07, 2012, 10:40:56 am »
/quote
/quote
Joachim,
Seems that this worked! At least I have brought back my system to the normal state by reinstalling 09z74.
But now it won´t let me minimize the system again... (with a fresh install of the same 09z74 model).
So I either have to find out how this thing with the automatic restore points work or I will obtain a new activation code and hope that either one works. Will try over lunchtime. Need to get the system back to work for a shootout with other players next week.
Thanks for all the help
Carsten
CaOd
« Reply #11 on: November 07, 2012, 10:10:15 pm »
I  have proceeded with a new clean install of XX09z75 model after cleaning everything of the previous models.
OS was in non-mimimized mode, allowing me to access the web and do the activation procedure for 09z75.
Worked out ok, but the problem maintains: Cannot minimize OS, rendering of coverart in unattended stays yellow-ish...
Any further help? Or do I have to do a clean new install of Win7? B.t.w.: I had not enabled restore points, so no way back...
Thanks Carsten
« Reply #12 on: November 08, 2012, 08:54:40 am »
Hi again Carsten,
No need to reinstall W7 at all. Well, it wouldn't help a thing.
But for now it is not clear to me whether your by now newly obtained Code also does not work. If all is right it is from before your last post. So, let me know that first ...
CaOd
« Reply #13 on: November 08, 2012, 10:28:53 am »
no, the newly obtained code from last night does not work.
As said, I cleanded everything, copied the 09z75 files to the drive and obtained a new activation code.
All looked good again (can chose core appointment scheme), until playing unattended (still yellow-ish border on coverart) and PA won´t engage.
Also Minimizing OS does not work.
Any fresh idea?
Thansk Carsten
« Reply #14 on: November 08, 2012, 10:59:10 am »
I sent you an email ...
We will put out here what went wrong, once it's solved.
