November 23, 2024, 08:53:19 am *
Pages: 1 [2] 3 4  All
Author Topic: SFS Sound Quality Experiences  (Read 48879 times)
« Reply #15 on: November 08, 2012, 10:07:57 pm »
Hey Boleary - I find exactly the same. I was listening to a very high quality simple female voice recording last night and ended up on SFS=2 because anything higher seemed to smear the voice.
« Reply #16 on: November 08, 2012, 10:29:45 pm »
...ended up on SFS=2 because anything higher seemed to smear the voice.
When PA was first released I remember posting something about the SFS issue may finally be solved. It's because of your observation that anything above 2 just doesn't sound "right"; it sounds a bit veiled or smeared. Also, Paul, what you said about the level of detail in your first post in this thread is exactly what I have here, and its crazy good. The other night I was listening to one of the quieter tracks on Bonnie Raitt's new CD--its just her voice and a piano Twice I distinctly heard a soft creaking sound that at first I thought was a loose speaker wire. Turns out it's the shifting of her body weight on the piano bench! But what's really amazing about my sound is the sense that its entirely natural and musical sounding. Its not harsh or edgey.
Truly Nobel Prize worthy!
« Reply #17 on: November 08, 2012, 10:48:02 pm »
Yes a Nobel prize for sure is due. Peter - consider it bestowed!!.  It is good to see the experience of others because I am never quite sure if things are working right here or not with no other reference point.
listening
« Reply #18 on: November 08, 2012, 11:02:42 pm »
I have the same experience with SFS=2 too. Additionally I recycled some spare memory and built up a RAM based playback drive. I know that this is a component from the dark past - but I found a sweetspot for my system.
Georg
-> SMSL SU-8 ES9038
-> 2x Neumann KH-120
« Reply #19 on: November 09, 2012, 09:18:20 am »
Georg,
Not a bad idea at all. It is only a week back that I thought of trying it myself, BUT these days it indeeds need more memory than my 8GB - so I just couldn't do it (well, it wouldn't be the best).
Anyway, it is just one of the "Playback Drive" options which should be tried !
Nice.
« Reply #20 on: November 09, 2012, 09:24:32 am »
Funny ...
Following this topic and yesterday reading again about SFS=2 etc., earlier in the day I thought "before I forget, let's set that SFS to 2 for tonight's playback session !". And so I did.
This morning I was puzzling a bit whatever now happened last night that really made me think : now what happened to my mains or whatever, because it sounded better last night than other times.
yea, well
I forgot about that SFS=2 completely last night.
And only now, reading the new posts in here, I thought of it again.
Generally the great people in this forum won't be fooled or placeboed. I won't be either.
But experiencing it by this means still gives a way better feeling.
« Reply #21 on: November 09, 2012, 04:06:38 pm »
Georg,
Nice.
Yeah I could use a ramdrive for that. But Only 4GB on this pc unhappy
« Reply #22 on: November 10, 2012, 05:07:09 pm »
I´ve been trying the Playback Drive in RAMDisk and the first impressions are that the sound is also very good, it seems smoother even than with my external hdd (WD RE4 WD5003ABYX) but the differences are subtle, I´m not sure yet if it is more detailed or not, I need to listen some more time but what I can say by now is that the RAMDisk makes another great PbD.
Thanks Georg, for bringing again the RAMDisk to the scene.
PS: Thanks also to George (nik.d) for pushing me to try the RAMDisck and remind me how to install it.
Stanray
« Reply #23 on: November 10, 2012, 06:12:55 pm »
Quote from: juanpmar
PS: Thanks also to George (nik.d) for pushing me to try the RAMDisck and remind me [i
how to install it[/i].
Uhh, How?  Huh !?
Stanley
« Reply #24 on: November 10, 2012, 08:24:16 pm »
Stanley, this should get you going I think : step-by-step set up of RAMDISK.....
listening
« Reply #25 on: November 10, 2012, 08:52:52 pm »
There is a little more complicated but very flexible free software solution running under Windows 8 and Windows Server 2012 in 64 bit mode too:
http://www.ltr-data.se/opencode.html/#ImDisk
Georg
-> SMSL SU-8 ES9038
« Reply #26 on: November 11, 2012, 02:18:16 am »
Hi Stanley,
This is what George (nik.d) told me:
I did not change any initial parameter except disk size, so the RAMDISK image (RAMDISK.iso) sits right at OS/XXHE disk root.
In case you use same software as I did (Dataram RamDisk Free: http://memory.dataram.com/products-and-services/software/ramdisk) you have to bring back PC from minimized into normal mode as installer complains and cannot proceed w/instalation because some services are not running. Second thing to do is to install
Microsoft .NET 4 platform. My PC is not connected to internet so I downloaded 'offline' installation found here:
http://www.microsoft.com/en-us/download/details.aspx?id=24872
So:
- Bring back W7 from minimized mode
- Install .NET 4
- Install RamDisk sw and choose either FAT16 or FAT32 filesystem. For free version disk capacity must be below 4000 GB
   (o/wise it will complain and not install ramdisk at all) I have named disk 'RAMDISK' so I know disk by name.
- Windows should report and list new HDD. Rightclick mouse format HDD to NTFS and 512b clusters (smallest)
- Try new HDD in XXHE (choose it for 'playback drive')
- Engage 'minimize OS' again
« Last Edit: November 12, 2012, 11:36:05 pm by juanpmar » Logged
Stanray
« Reply #27 on: November 11, 2012, 05:42:08 pm »
Thanks Juan, Georg, Peter!
@Juan:
4000GB should be 4000MB, 4GB I recon.  Wink
It works fine (haven't compared the SQ yet though). The only thing is when I reboot, the name RAMDISK I gave, is lost and it becomes named "Local Drive". It doesn't keep the RAMDRIVE name. Any solution for that?
Stanley
« Reply #28 on: November 11, 2012, 07:05:09 pm »
....I´m not sure yet if it is more detailed or not, I need to listen some more time but what I can say by now is that the RAMDisk makes another great PbD.
Hey Juan, I don't know what "PbD" means? Am really interested in your and others impressions regarding SQ with RAMDISC. Any further thoughts?
Brian
« Reply #29 on: November 11, 2012, 07:06:38 pm »
PbD=Playback Drive  Happy. Still testing the RAMdisk but the sound is great, as I said in a previous post it seems smoother than with my external drive but I need to listen some more time to be sure which option is the best one.
