November 22, 2024, 07:04:25 pm *
Author Topic: Still some ticks with 0.9z-7-5  (Read 28143 times)
« on: October 14, 2012, 10:03:39 pm »
I installed some days ago the OS and since then I was hearing some ticks and cracks. Today I´ve installed the new  0.9z-7-5 and two or three ticks are still there one just at the start of the first track in the Playlist and the other ones a few seconds inside this first track. No more cracks when changing volume or at stop.
Some questions,
- with this version I understand that it is not necessary to install again XXengine3.z74.rar in order to avoid the cracks when playing with low SFS, as it was only made for the 7-4 version. Correct?
- Not always but frequently after playing some tracks when I stop XXHE and turn it Off the X icon disappears from the task bar but when I click again in the desktop icon to turn it On a message appears: XXHighEnd is already running. Kill the other instance/s?... but the program is not running anymore...This issue was happening also with the previous version the same way that happens now with this new one. As it is happening after I re installed the OS maybe I did something wrong.
In the Task Manager I can see XXEngine3.exe and three or more XXHighEnd.exe depends on the times I´ve tried to turn it Off/On and I can´t kill them with End Process, to do it I have to reboot the computer.
« Reply #1 on: October 14, 2012, 10:08:39 pm »
Peter, I realized that it takes a few minutes to appear XX again after I clicked in the XXHighEnd is already running. Kill the other instance/s?... message. The Playlist is still there even when I cleared it before.
« Reply #2 on: October 14, 2012, 11:00:37 pm »
I set the parameters to suppres the cracks to there default value. After a stop i clearly hear one or two cracks before it stopped. So i changed the parameters to the old values.
praphan
« Reply #3 on: October 15, 2012, 06:59:12 pm »
Downloaded and installed z-7-5 then hooked up my voltmeter to measure AC pulse at speaker binding posts as usual.
At low SFS (2) and low net buffer size (15x1x4096) , z-7-5 brought back audible ticks at changing volume and powerful LF plop at stop - the same way as I experienced in pre z-7-4. Increasing SFS and net buffer yield even worse annoying tick and plop.
I will adhere to z-7-4, the version that I can tweak (my XXHE setting, bios setting, device driver choice) to get softest plop at stop (very mild LF pulse). Moreover, mild tick will occur only once at the first click of digital volume change in a particular track. The subsequent change in digital volume in that same track will produce no more tick at all.
Luckily, this low SFS and net buffer size yield a better SQ in my system too.
Praphan
« Reply #4 on: October 15, 2012, 07:10:59 pm »
Praphan
I realized that it happens to me as well, besides all the other things I stated in the previous post. I installed again the OS.
Robert
« Reply #5 on: October 16, 2012, 09:11:02 am »
Gosh I'm reluctant to download this version also. The last one(Ver4) was a mission to get working and its certainly working fine for me now. I'm beginning to wonder if Linux is a better option perhaps Windows has had its day for audio! Really I'm over replacing the OS to recover from glitches, we just want the music. I have to say I'm on the road to a dedicated server build.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #6 on: October 16, 2012, 10:15:02 am »
Of course not. I mean, it's just me - so to speak. Well, sort of.
I guess the first thing you guys must do is deactivating Phase Alignment. Ehm, it is too difficult ? for me the same ?
I'm almost serious because what I read so far in this topic all doesn't seem to make sense. So, that is a problem too - how do you make clear towards me what is going on.
Johan, what do you think the default values are, and at which values it did not work for you ?
Juan, you got it right. Point here is that these first ticks you may perceive are outside Arc Prediction; this is about showing the Wallpaper which is too offending for the system (and to me it seems that the faster the system the more offending it is). So, it stalls the stream briefly and this is what you now hear with Arc Prediction. Shut off Arc Predition and it will still happen, only now you must be able to perceive a few ms of silence. yes Anyway, this is what the "After SFS Rounds" setting is for.
Maybe I should have mentioned in the Release Notes that this really is unrelated to Arc Prediction itself (hence it can't be solved in there).
But Praphan, why ? Did I ever ask you to do this ? So ...
So you thought it would be a good think to measure an as low "LF Plop" as possible ? haha. Can't work. Can't work because too many parameters play a role at the same time, and it's even so that the "better" that LF plop is there, the better Arc Prediction works. And no, now don't try to make it as large as possible. Happy Happy
What I *can* try to "teach" is that, generally, the more SPL coming from stop, the more fast the "fade out" went. Now think about the relation to the volume - the higher the volume the faster fade out is needed within the given time (which is your SFS and also net buffer size).
What I sure can admit is that when things are not working properly that fade out can shake the house (say all the doors). But as far as I'm concerned this is not the case at all in any of the playback means which allow Phase Alignment. Still : the lower the SFS the more firm it will be.
My official response here should be : impossible. And following from that : you must have something else wrong. However, two things : 1. Of course if yuo say it I believe you, and/but 2. you (again) should be oberving in decent fashion.
Still I can't believe it ...
And this neither. swoon
Here though there might be something which wasn't thoroughly tested and this is about making changes to settings and to what degree they are processed "decently". So Praphan, it might be something for you to retest a few things, but now first kill XXEngine3.exe before you start playing with a new setting. If you also test other formats, I'd again kill XXEngine3. And a bit of an "inside" problem : when I tested everything (which took two full days) I need to kill XXEngine3 which is log file related ...
So let's hope this makes things better and then I know where to look for.
Otherwise, please try the setting I have been using without any single issue since 0.9z-7-5 (which was Sunday) : SFS=60, Q1=14, Q1F=1, DevBufSize = 4096, volume -30 to -18 and changing it all the time.
One last thing that I notice myself now (and which has been reported by others) : Most often I quit the album before it's finished. So, press Stop (or Alt-s). However, the one or two times the album finished by itself (or End of Track was engaged) I seem to notice that more "shaking" end. So, if you mean *that*, then by now I should be looking in that direction. Could also be important when you further (like to) test, and just pressing Stop each time may incur for nothing serious.
Really, I hope it hasn't gone too difficult ...
« Reply #7 on: October 16, 2012, 10:28:29 am »
Well, if I see how many times (eh, per day sometimes) you guys reinstall the OS because you think that will help ...
I'm afraid it won't go otherwise for you, but I wish I could make clear in one post how to know whether the reinstall of the OS may help you with ... yea, what. It hasn't been the solution for me one single time ever, but that's part of your problem ... I seem to know what I'm doing. But to put it as it should be : I pay attention to everything and when suddenly something changed for the worse, I tend to know fairly quickly what did it. So, it's about the paying attention, *and* to the proper things. And this can't be explained ...
Once you have the OS running like you think it should, make an image copy of it (Acronis True Image really does a good job) and when needed you can restore that in 20 minutes or so (keep the partition of the OS small) with all your settings.
Of course this helps a lot, if not all; when you perform other normal work on the Audio PC - let alone if others are on that PC as well - then it could be too much of that payting attention for a normal human being.
Still it requires some specialities like not switching on Windows Update.
I don't think this helped a lot. I still tried ...
« Reply #8 on: October 16, 2012, 10:42:26 am »
Peter, what could be origin of the problem I find and that I explain it in my first post:
- Not always but frequently after playing some tracks when I stop XXHE and turn it Off the X icon disappears from the task bar but when I click again in the desktop icon to turn it On a message appears: XXHighEnd is already running. Kill the other instance/s.... This issue was happening also with the previous version the same way that happens now with this new one. As it is happening after I re installed the OS maybe I did something wrong.
The OS that I installed has 98 updates, with them installed the problem doesn´t exist but if I eliminate the updates (but the only one impossible to eliminate) the problem appears again, I´m trying now to know what are/is the update/s that avoid the problem. Although maybe the problem is not due to the updates but a bad XX configuration in my computer
Robert
« Reply #9 on: October 16, 2012, 11:38:43 am »
Look Windows is an absolute pain. After reloading I have to spend time shutting down services and then I'm never sure I've got them all. Dedicated software does away with this.
Lets face it, Windows is designed for everybody but not "us dedicated audiophiles". Honestly its got to be simpler.
Perhaps you need a windows version that suits everybody and a dedicated audio version that is designed to suit exact or near minimum hardware setups such as yourself and Juanpmar.
In saying that I do appreciate all you have done and I do love the sound I have with my cr*ppy laptop which still beats my CD setup. PA is still a viable thing. The problem is making it work across a multitude of setups. The DC thing is a problem for most. They don't have the insight or gear to do it.
We have to try new things in the digital domain to push the boundaries and you are certainly doing that.
This is mean't as constructive advice not a criticism, I want XXhighend to work "easily" and sound amazing. Its got to be simple to work.
I have no proof but I'm blaming Windows!!!! Its never been right!!!
Oppo 205 UDP Dac
« Reply #10 on: October 16, 2012, 01:51:07 pm »
Robocop ... I don't get it ...
This is what XXHighEnd is doing for you. So, what do I miss here ?
Or you maybe ? Happy
« Reply #11 on: October 16, 2012, 01:59:12 pm »
Juan,
The only thing I recognize myself is that 0.9z-7 is prone to not get out of memory as fast as before. And I think I know what causes this although I never really tried because it doesn't bother really. Well, not me. But as it seems it bothers you ? ... and not sure how OS updates can be involved with this ...
Anyway for sure XXHighEnd.exe will vanish from memory but it may take 5 seconds sometimes. Not that you will see that on the GUI (which disappears right away).
Btw, if the solution is not to install those updates, then so be it. But is it ? it is not 100% clear to me.
What you can do to confirm my guesses about this, is go to teh Scaling button ([ S ]) and remove all the references to image files. So, for button backgrounds, form backgrounds, everything. I think that may help ...
And maybe superfluously : when XXHighEnd keeps on running you pretty much can't do a thing (well) anymore; mechanisms are in there that wait until the other version has closed down before proceeding (changing the Volume during playback would be an example of it).
Arjan
« Reply #12 on: October 16, 2012, 03:14:00 pm »
I like to tell my experiences with 7-5. Since I use a 24bits Audiophilleo I can use PA now for the first time.
As DAC and Pre I use a NAD M51 with digital volume control. So the Digital Attenuation is fixed set to -10.5. I only have soft cracks during volume changes on the dac.
At stop I do not have a crack with Phase (-) but when I use Phase (+) I get a louder crackling sound on my right speaker at stop. So I stick to Phase (-). At stop I get a small repeat before it stops.
So far I really like the sound!
kind regards
March, 2024 (2.11)
praphan
« Reply #13 on: October 16, 2012, 04:00:23 pm »
My official response here should be : impossible. And following from that : you must have something else wrong. However, two things : 1. Of course if you say it I believe you, and/but 2. you (again) should be observing in decent fashion.
Thanks for a thorough elaboration.
I developed a habit to measure the LF pulse since I don't like it even though it is not audible. This is because I hate to see large excursion of the woofer diaphragm. I know it is not harmful but this is some kind of "obsession". So what I am looking for is to eliminate the LF plop rather than accentuate it. This is achieved with my low SFS and net buffer setting in z-7-4. The fade out at stop is fast though but at a higher audible frequency,  very mild and felt unharmful to me.
I must admit that I did apply an undecent test on z-7-5 last night. I think what went wrong yesterday was that I tested 7-5 in full OS mode and attended.  I am quite certain that I clicked minimize OS after activating this new version which should reboot the system into MIN mode. But when I booted my audio PC today, it was not. The min OS button was blue. So I had to reboot into min mode. Therefore the 7-5 test last night was conducted under the full OS mode (attended too) which was not decent. Moreover, I used small bookshelf speaker and therefore audible crack was heard at changing digital volume. When I changed the net buffer setting and SFS size, I also gave too high the value.
I conducted a more decent test on z-7-5 again today at your recommended setting NB 14x1x4096 and SFS 60. You are right, no audible tick/crack at changing volume. But instead an inaudible mild LF plop *each and every time* the volume is changed with about 3-4 second delay after the command. Just watch the woofer diaphragm. At stop or next track command is given, larger (than that of changing volume) LF inaudible plop is seen on diaphragm. However, this is at a lesser excursion than what I saw on z7-3 and before.  I think I can leave with this if you insist that LF plop things should be allowed and maintained which indicates that AP is working at its best. Which in turn yielding a better SQ ?
So my bad and switching to 7-5 today.
Thanks and regards,
Praphan
PS : I also noticed that more complicated thing is going on at the end of the playlist when the streaming stop. Not only simple plop but combined with crackkkkinggggg but short though. So what I usually did is hit Alt-S like you, or even turn off the main amps before the end of playlist if I am done with the listening session.
« Reply #14 on: October 16, 2012, 04:23:56 pm »
Juan,
- Well, it bothers because several XXHighEnd.exe are running at the same time although they can only be seen in the Task Manager. The problem is if that there is more than one XXHighEnd.exe running at the same time it is impossible to load a new Playlist and play music. As I say the only way to solve it is to restart the computer. I´ll try to see if waiting for more than 5 seconds after I turn it Off solves it.
- It is supposed that the updates don´t have to be installed in order to get the best possible SQ. With the updates installed don´t exist the problem mentioned but of course I have to try to get the best SQ. At the end I took out all the updates but the only one that can´t be uninstalled.
- I don´t have anything clicked in the Skin Settings, so plain GUI.
Btw, no more clicks since I use your settings (SFS=60, Q1=14, Q1F=1, DevBufSize = 4096, volume -30 to -18) and:
- After SFS rounds: 2
- Fade-out Step (3): 3
