April 20, 2025, 08:34:29 am *
Author Topic: Playback of DTS encoded WAV's  (Read 6197 times)
« on: October 19, 2007, 06:19:23 pm »
Hi Peter Happy
I have a number of multichannel albums encoded in DTS ( they are in WAV format for those not familiar ) and i was pleasantly surprised to discover that XX plays these nicely also because it doesn't corrupt/resample the data. One slight problem though is that a number of my albums are at 48K rather than 44.1K and those aren't handled currently by XX. I seem to recall you mentioning in another thread that later versions of XX may suppose files encoded greater than 44.1K.
Is this a likelihood ?
For those not familiar with multichannel sound ( like myself a year or so ago ), there are some samples available to experiment with from Swedish Radio ... http://www.sr.se/cgi-bin/mall/index.asp?ProgramID=2446
Cheers all Happy
« Reply #1 on: October 19, 2007, 07:18:03 pm »
Hey Russ ... Yep; in the future any fed samplerate and bit depth will be supported.
I may have some comments on the DTS playback later (must try a few things here) ...
