April 02, 2025, 09:52:52 am *
Author Topic: Peak Extend Conundrum  (Read 37251 times)
« on: October 09, 2012, 10:57:13 pm »
To Peak Extend or not that is the question?
Since installing 9z-7-4 I find that Peak Extend has a very significant impact on SQ.
I certainly prefer PE *OFF*. The sound to these ears at least is more alive and with the right recordings of the highest SQ I have heard in this system. BUT sometimes it seems to me that the sound is just a little untidy - but strangely I can still listen to it for hours without fatigue. Sometime I do get tempted to listen to a more tidy sound so I select PE to be *ON*. But then the sound is not as *live* sounding and becomes smooth - too smooth. On balance PA is going to stay *OFF* except maybe for the most wayward of recordings.
But sometimes I just wonder if there is just a little too much going on in the higher reaches of the frequency spectrum. I am certainly not complaining though SQ is simple excellent nowadays. So much so I am thinking of getting a new hobby - listening to music ha ha!.
P
« Last Edit: October 10, 2012, 11:07:09 am by Scroobius » Logged
« Reply #1 on: October 10, 2012, 09:17:39 am »
Paul - hats off to you.
So here's my little secret which I don't want to keep a secret at all ... But, I sort of challenged you (all) and was waiting for a response like yours ...
If you have followed what's going on with not-Peak Extend, then you'll know this is about some compiler bug. I again tried to solve it but couldn't. And, if you'd really dig into the subject again, you'd see that only when I applied a fraction to the volume like 0.001 (0.0001 already implies the bug, and doing nothing like x 1.000 also implies the bug) then ...
From all comes that I solved it by applying that fraction. The effect ? the volume is not "lossless" anymore. So, my ever back "invented" good volume is distroyed here; it 100% exactly exhibits like you describe ...
That's why the hats off.
With Peak Extend this does not happen. So there you have all of the good attenuation which is 100% linear. Without PE it is not ...
So see ? this *is* audible.
Good job,
« Reply #2 on: October 10, 2012, 10:04:57 am »
Fa, blue-eyed Paul gets all the credit.
Waaaaaaaay back (OK, on Monday), I wrote:
I have to say that ever since I stopped using Peak Extension [since the release of 0.9z-7-4], I started finding the sound way too 'forward' and 'sharp'. But I've found it hard reverting back to PE, for psychological reasons more than anything else...
But I agree with everything Paul says about the change in SQ.
« Reply #3 on: October 10, 2012, 10:13:12 am »
On balance PA is going to stay *ON* except maybe for the most wayward of recordings.
Hey Paul, surely you mean *OFF*... no?
« Reply #4 on: October 10, 2012, 10:18:45 am »
Okay Mani, so you were first ! But ... I didn't see it like that because you sneaked out the context today. This was like this :
In the release notes for 0.9z-7-4, Peter says:
From off its introduction Peak Extension was the means to solve distortion which "officially" was only measurable outside the audio band. Now not activating Peak Extension operates without this distortion.
Do notice that the distortion implied a clear difference in "sound", but that it was very hard to not find this distortion to work out better (sound wise) than without it; it was merely the other way around. So, this "feature" (that assumed) has been eliminated now, but for those used to have the distortion in for the better, it could be made a real feature (no matter how strange). So please report if you think it is annoying that this distortion is out of the way now (we are serious).
[The highlight is mine.]
I have to say that ever since I stopped using Peak Extension, I started finding the sound way too 'forward' and 'sharp'.
So see ? I was put on the wrong track because I could only read it in the context of the distortion now being out of the way and *that* possibly wasn't liked better.
I really didn't think of that now new "anomaly" (knowing very well what I had done) bugged you.
So, distortion out of the way, but a new one introduced.
Btw, use Peak Extension again, and all is without distortion, but loose ~3dB ...
« Reply #5 on: October 10, 2012, 10:21:16 am »
Or PE On/Off ?
scratching
« Reply #6 on: October 10, 2012, 10:27:19 am »
And we're long-term XX users - can you just imagine what it must be like for someone coming across XX for the first time?
I was referring to PE *OFF* being Paul's default setting as it seems he likes the more 'alive' sound.
For me, as I said, it's just too 'forward' and 'sharp'. Changing ICs has helped to calm things down, but I'm not really happy with this. I think I'll use my cheap 'anti-cable' ICs (I love 'em) and revert back to a default setting of PE *ON*.
« Reply #7 on: October 10, 2012, 10:33:12 am »
Please never forget my almost Rule #1 : when something like this helps, something has to be wrong.
« Reply #8 on: October 10, 2012, 10:33:29 am »
I must admit something :
When I changed this, I was ignorant enough to never even explicitly listen to the result. I never did. But, since then I started to switch Off PE.
but
Day before yesterday we were telling to eachother that some familar album was "on the edge". And it wasn't that before.
In the mean time I had forgotten about the PE change by long. But know I know again of course.
Will undo that change which makes it back to that *other* distortion. swoon
Or try to solve it after all ...
PS: We played with this at the X-Fi show. Tongue
« Reply #9 on: October 10, 2012, 11:07:56 am »
Oooops yes I did mean to say: -
"On balance PE is going to stay *OFF* except maybe for the most wayward of recordings. "
I have changed my post above.
« Reply #10 on: October 10, 2012, 11:12:06 am »
Hey Paul, you may as well change 'PA' to 'PE' while you're at it Happy
« Reply #11 on: October 10, 2012, 12:03:21 pm »
Duuurrgh its one of those mornings. As you say if we get confused what chance a Newbie?
« Reply #12 on: October 10, 2012, 12:23:25 pm »
Peter - Although I agree with your Rule #1 in general I do not in this case.
When I was listening to speaker cables I first listened to bare copper wire. I then listened to lacquered copper wire. I could not hear significant difference. But both sounded MUCH better than my expensive copper speaker cable. It seemed to me that the absence of plastic could have been the reason for the good sound.
It seems to me that simple lacquered wire should be the most neutral option for speaker wire. Certainly my old PTFE coated speaker wire blurred the sound but also added an edge to it.
So maybe Mani in this case is hearing the benefits of anti cable not adding more grunge to the sound than is already (possibly) there due to PE *off*.
Mani - out of interest have you twisted the anti cables to reduce inductance?.
« Reply #13 on: October 10, 2012, 12:50:12 pm »
Peter - please correct me if I am wrong but my understanding from what you have written above is: -
1.  Your latest mod to PE (x .001) works around the compiler bug but introduces distortion because the volume control is no longer lossless.
2.  With PE *on* multiplying by -3db also works around the compiler bug but does not affect the lossless volume because it is multiplying by a *whole* number.
If 1. above is correct I have to say I much prefer the distortion due to lossless volume not working than the "truncated transients" distortion of previous versions.
« Reply #14 on: October 10, 2012, 01:41:19 pm »
Comfirmed Paul.
