November 23, 2024, 02:33:16 am *
Author Topic: Undemo won't go  (Read 6427 times)
Robert
« on: September 29, 2012, 09:34:37 am »
Gosh everything was working great PA included and then my HDD died.
Have new HDD, reload os and now can't undemo version 4 with 7 code. I've tried almost everything. Should it work with existing 7 code do I have to paypal or other?
We do get music though with PA on just can't undemo.
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: September 29, 2012, 11:33:06 am »
Yes you can activate XXHE, provided that your activation code is about 09z-07 official release version, the PC is the one it was activated upon and the PC name is the same (ex: ALAIN-PC not the same as PC-ALAIN). I do not think that the HDD has anything to do with activation (it can be changed without the need to ask again for a new activation key).
The next part is to follow the notes about playing a while with XXHE before entering your activation key.
stefanobilliani
« Reply #2 on: September 29, 2012, 11:53:44 am »
Once you reinstall the OS the needing of a new code by paypal is mandatory .
S
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
Robert
« Reply #3 on: September 29, 2012, 11:48:38 pm »
Thanks guys after much sweating I Paypal ed a new Activation code and after doing a new install it worked. XXhighend is working in all modes now. I need to relisten and play with settings.
When you do a new OS install why won't the Activation code work(I had a current z7 code)? All other programs(CD rip etc) I just copy and pasted and they worked.
Probably needs to be a post on this point for future reference.
Oppo 205 UDP Dac
