Diede
« on: September 26, 2012, 10:29:10 am » |
I just downloaded and installed XXHighEnd-09-z7.4. Everything works perfect and first impression is that it sounds even better then XXHighEnd-09-z7.3.
I do have one issue though, when I hit the 'Stop' button the last sequence continous in loop. The only way to stop it is to kill engine 3 with the 'Off' button.
I tried with Fade-out steps 0-3, nothing changes.
Best regards, Diede
W8 and W10 - June 8, 2015 (2.02) XXHighEnd PC (own build) -> i7 4930K Hyperthreading On (12 cores), 16GB, Windows 8 Pro 64bit or *Windows 10 Pro 64 bit Insider Preview build 10074* on separate SSD’s, XXHE on 2GB RAMDisk (IMDisk), music on internal spinning disk & LAN (*always On*) / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = *4* (max 60) / not Invert / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core3-5 / Playback Drive 2GB RAMDisk (IMDisk) / UnAttended / All Services Off / Keep LAN - *Persist* / WallPaper *Off* / OSD *On* /Running Time *On* / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600 or High 705600* / -> USB3 (Silverstone non isolated) Sw#3 of NOS1a = down) -> *WireWorld Ultraviolet USB Cable 1m* -> 24/768 Phasure NOS1a async USB DAC, Driver v1.0.4b (*4ms*) -> own build NCore NC1200 amps (4 mono per channel), own build of Orelo MKI Open Baffle Horn Speakers
« Reply #1 on: September 26, 2012, 12:27:50 pm » |
Hi Diede,
With what further settings is this ? (SFS, Q1, Q1F, DevBufSize, input sample rate, output sample rate)
Diede
« Reply #2 on: September 26, 2012, 12:54:26 pm » |
See signature data:
Engine#4 Adaptive Mode / Q1/2/3/4/5 = 6/0/0/0/0 / Q1Factor = 1 (Dev.Buffer = 4096) / ClockRes = 15ms / Straight Contiguous / SFS = *2*/*2* / not Invert / *Ph minus (strength 0-1)* / Playerprio = Low / ThreadPrio = Real Time / Scheme = 3 @ / All Services Off except RDC and PAN / No Running Time / Minimize OS = On / Double Octo Arc Prediction Upsampling / -> 24/768 Phasure NOS1 async USB DAC, Driver v1.0.2 (16ms)
I'm running in attended mode for the time being.
BR, Diede
« Reply #3 on: September 26, 2012, 07:40:37 pm » |
Diede - you are completely right. With an SFS under 8 it "loops" at the end. Not good ... Something to solve.  Thanks ! Peter
« Reply #4 on: September 27, 2012, 07:55:13 am » |
- you are completely right. With an SFS under 8 it "loops" at the end. Same loping effect here with a SFS =12/12
« Reply #5 on: September 27, 2012, 09:31:44 am » |
I will solve it anyway, but Johan ... just curious, what other settings go along with this ? (SFS, Q1, Q1F, DevBufSize) So, before I focus on that "under 8" while other situations incur for the same, I rather know the other situations ...
Thanks ! Peter
« Reply #6 on: September 27, 2012, 09:41:19 am » |
It's all in my profile : ......Q1=14 / Q1Factor = 1 (Dev.Buffer = 4096) / ClockRes = 15ms / Straight Contiguous / SFS = 12 /.......
« Reply #7 on: September 27, 2012, 09:59:32 am » |
LOL. So Johan, are you saying that SFS=8 works and SFS=12 again not ? (you never said that of course, but it should be my conclusion)
« Reply #8 on: September 27, 2012, 10:11:28 am » |
SFS 12 is the lowest workable value for me!
« Reply #9 on: September 27, 2012, 10:30:07 am » |
Aha, interesting ...
What is the latency (ms) in the Driver Control Panel ? I tested this with 4ms, so it is here where the difference must be ...
« Reply #10 on: September 27, 2012, 11:00:57 am » |
Can not verify it at this moment. I'll inform you this afternoon.
praphan
« Reply #11 on: September 27, 2012, 07:24:26 pm » |
Thanks ! Peter
Hi Peter, Since I am also as curious as you, I hooked up my spare bookshelf speaker to my tube amp and check this "loop" phenomenon out. I have developed a habit of checking the DC and LF AC pulse at the hit of stop on all new XX release before feeding the signal to my more expensive speakers. This LOOP from the stop is related to : (1) SFS : in my case below 6-8 is already a problem (2) Rate of AP upsampling : At SFS = 2 and 1xAP (or no upsampling at all), you will have a very short loop. At SFS = 2 and 4xAP, the loop will be a little longer. Then at double octo AP , the loop seems to be forever. (3) The level of digital attenuation : the louder the digital volume, the longer the loop. At -40 dBFS , 8xAP and SFS of 10, very short loop. All other fixed settings are : net buffer size = 4096x14x1, Phasure driver latency of 4 ms, PA - engaged. I found this loop syndrome in z7-4 (implying low SFS, high volume and high rate of up sampling) to be dangerous to my system. Killing XXEngine 3 to end the loop will follow by strong punchy crack. I tried rebooting my audio PC to see if things will change. And yes after one of the reboots, I encountered the loudest crack ever (with a AC pulse of +/- 1.5v reading) immediately after the first start of the track. This pulse triggered the protection circuitry of my amp and hence cutting the power immediately.  Luckily, I tested this with my bookshelf speaker.  Switching SFS to 60 seems to bring crack at the start and plop at the stop to be on par with z7-3. One improvement that I found on z7-4 is that *at SFS = 60* the click and/or crack from the change of digital volume is disappeared (no AC pulse on the meter) Without engaging PA, XXHE behaves nicely. Haven't got a chance to check the SQ though. I have to be comfortable with bookshelf speaker test before connecting my B&W to the amps. Hope the above helps. Kind regards, Praphan
XX 0.9z-8-3a : KS Engine 4 "Adaptive"; DB = 4096; APx16; Q1/2/3/4/5 = 14x1/0/0/0/0; No Appointment/low/real time; CR = 0.5 ms; XTweaks Ultimate; SC; SFS= 120/120 ; allow format change; unattended ; min OS and stop "all" services; normalized volume usually played at -15db ; peak extension on ; PA off
« Reply #12 on: September 27, 2012, 08:50:20 pm » |
Thank you so much Praphan.
Kind regards, Peter
« Reply #13 on: September 27, 2012, 09:30:09 pm » |
What is the latency (ms) in the Driver Control Panel ? I tested this with 4ms, so it is here where the difference must be ... The latency shows 4ms. I have the impression when i abort playback i got the loop. When i play until the end in unattended playback the wallpaper remains at the end and xxhe won't go to its innitial state. Phasure USB audio control panel isn't active anymore. XXHE won't start anymore. I need to remove the audio engine from the memory to start XXHE again. Johan
« Reply #14 on: September 27, 2012, 09:36:53 pm » |
Below there's a version of the sound engine that won't go into the loop. BUT, it also doesn't go into any second loop of buffer playing. This means :
- Whatever helped a kind of falsely in previous 0.9z-7 versions now isn't there anymore;
- That it is totally clear that Q1 x Q1F x DevBufSize determines the length of the fade-out granted (when too short : TICK);
- That the Fade-Out parameter in XXHighEnd's settings will only make it worse when set longer than the default of 3 (the fade-out will always be cut by the buffer length). Notice that shorther won't help either once the standard "3" does not work.
- That the SFS (size) can't have an influence really anymore (good by itself) UNLESS it implies a shorther playback time than the buffer length depicts.
- That because of the eliminated anomaly in the first place, now sooner a small tick may happen than a larger which latter actually even repeats (there is no repeat anymore).
- That people using KS Special Mode may run into special strangeness which I myself can't test. But the main rule remains : increasing the total product of the buffer size must help.
And keep in mind : the less Digital Attenuation (so, the louder the volume), the more difficult it will be.
Let me know what happens ... Peter
PS: Be careful that you (later) can differentiate between this version of XXEngine3.exe and the one originally belonging to 0.9z-7-4; you won't be able to see it on anything except by the date/time of the .exe (this one being from the 27th of September).
