« Reply #30 on: October 04, 2012, 08:34:47 pm » |
Try Google Translate ... NOT. You know MY English ...
« Reply #31 on: October 05, 2012, 10:33:06 am » |
Hi Maxi, I did not know you lived in Madrid, if you are interested in knowing the NOS1 and you want to share our experience I´ll be delighted. I do not know if anyone else is in Madrid or even in Spain, but if that´s the case I invite those interested to contact with my personal mail.
Btw, are you using a Playback Drive?. I´m not sure, but using it avoids many of the unwanted issues.
Cheers, Juan
« Reply #32 on: October 05, 2012, 11:56:45 am » |
Maxi,
In some bright moment last night I suddenly thought of the solution for you : set Phase to Normal, Ph- and swap the polarity of your loudspeaker cables ...
Sounds too easy for a solution, but should work. Or ?
Regards, Peter
phantomax
« Reply #33 on: October 05, 2012, 12:36:11 pm » |
Hi, Juan Yes I live in Madrid and I would be happy to visit you and hear the NOS1 and, of course, you are welcome to visit me and hear the ... well, the thing. We'll be in touch. BTW I am actually using a playbackdrive.
Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
phantomax
« Reply #34 on: October 05, 2012, 12:48:32 pm » |
Hello Peter, Thank you, I'll try. At this moment I am playing the DacMagic and seems that there is no problem with SPDIF: optical from Prodigy soundcard and electrical from internal soundcard. But, of course, PA can't be activated.
Regards
Maxi
« Reply #35 on: October 05, 2012, 04:14:50 pm » |
Maxi, But, of course, PA can't be activated. Of course ? I don't know why, but then this excersise has been without reason from the start ?? Regards, Peter
phantomax
« Reply #36 on: October 05, 2012, 04:45:46 pm » |
Hello Peter! I am playing with the speakers polarity swapped as you suggested. I am using an old pair of shelf speakers so I can't tell much about the SQ differences with normal phase and PA -. But I've noticed that, as you predicted, things are going better with PA+ and inverted phase although finally ther was a point when the protection circuit was tripped after a loud crack. I must admit that I don't even dare to try inverted phase and PA- (my wife is going to kill me ...if I don't suffer a heart attack before). I think I must live with the fact that only normal phase an PA- is possible in my system. I perceive the sound as the better I ever had so no worry about that. When I detect a recording wich I suspect that could sound better with inverted phase then I always can deativate PA.
Once again, thank you for your support.
Maxi
« Reply #37 on: October 05, 2012, 05:02:05 pm » |
Ok, good Maxi ! One last remark then : I think I must live with the fact that only normal phase an PA- is possible in my system. This sounds a bit like "oh well, nothing else is possible". Okay, but when you play like this and the polarity at the speakers is reversed, it is uncompromised (assumed that the phase is inverted elsewhere another time, which is what I understood). So, you are all good now ! Kind regards, Peter
phantomax
« Reply #38 on: October 08, 2012, 01:33:30 pm » |
Hello Peter,
this is just an update: playing with the main pair of speakers with swapped polarity and the sound is EVEN better. Not a big difference but it's better.
This is a little bit off topic but I take the opportunity to comment you that, although when I push stop there is no plop at all, when the music stops by itself sometimes there are plops again. I didn't notice it before because last week I have been testing all the time and I didn't let the music end very often. I'll try other buffer settings again.
Best regards, Maxi
