April 17, 2025, 09:12:05 am *
Author Topic: 24/96 or 24/192  (Read 11905 times)
xp9433
« on: October 18, 2007, 01:13:34 am »
I was thinking about ripping some of my LPs at 24/96 or 24/192 to hard drive.
Can I play them back at this sample rate through XXHighEnd without having to downsample to 16/44.1 (assuming my DAC can handle it)?
Frank
« Reply #1 on: October 18, 2007, 09:31:06 am »
Currently not Frank. But in due time it will ...
TJF
« Reply #2 on: February 14, 2009, 12:45:09 pm »
XX cannot play 192kHz-files like from linnrecords.com ?
Regards
Thomas
« Reply #3 on: February 14, 2009, 01:02:10 pm »
Hi Thomas,
Oh yes. This topic is a bit old I guess. Happy
Since a year or so all bit depths / sample rates from 16/44.1 up to 24/352.8 are supported.
Or do you mean you can't get it to work ?
TJF
« Reply #4 on: February 14, 2009, 01:16:19 pm »
no, no... Wink Thank you. I will try the next time in my new system... But the first thought, only 44,1kHz files... was shocking...
By the way: Do you know about problems in the actual Win7 Beta?
Regards
Thomas
« Reply #5 on: February 14, 2009, 02:56:26 pm »
No, never tried W2007 yet. But I will the RTM as soon as possible.
