November 24, 2024, 05:27:52 am *
Author Topic: Windows Activation Question  (Read 22299 times)
« Reply #15 on: September 22, 2012, 02:36:47 am »
I haven't the time to read everything here.  But Peter, you know my XXHE Windows HD has never been online.  I activated by calling MS over the phone (when you choose to activate they give you this Offline Activation option... giving them my number from the valid Win7 pro, and they then gave me a long ass number to type in, and I'm activated.  I only run XXHE HDD in minimzed mode and have never booted back to normal.
but,
When i start windows I don't see this message... but after playing XXHE for awhile, I see a message like, "this copy of windows is not genuine" even though I did an offline activation. I just laugh and figure it's you messing around with windows and MS doesn't like that.  Doesn't affect SQ and when I start up the next day it's gone until I play XXHE again... which is the only thing that HDD does.
Oh ya, I should say that I've always seen this message when running in Min mode.  Even when I ran the previous OS of Win 7 activated online.
« Reply #16 on: September 22, 2012, 08:06:27 am »
Okay Dave. I know about this offline method (performed it myself in some other situation), but as it seems to me it may serve two purposes :
1. Your Key does not work *and* the grace period has expired and so you virtually get a new Key (by means of this offline procedure). Whether that also Activates ?
2. Something went wrong and the PC nags about needing Activation. This is a bug within itself, and the offline procedure solves that (hey, I can do a few things offline just the same).
In both cases the message won't pop up anymore and neither case may (indeed) go wrong after going online. This makes you being correct.
It is all quite confusing. For example, I have a PC at hand right now which wasn't given any Key during the install. And no, you don't need to enter it right away (this is W7 Professional). And you know what ? this thing is expired right out of the box. So, it works, but the 30 days grace period are over right away. The offline procedure can't be performed because the PC isn't even to be given a Key right now; the customer has one ...
Anyway, I am pretty sure that I now have the same message/question as that from the other customer this topic is about. But the situation is very different.
stefanobilliani
« Reply #17 on: September 22, 2012, 10:12:11 am »
Hi Peter , do we read 'Status not available' and 'Product ID not available ' or something similar maybe ?
thanks
stefano
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #18 on: September 22, 2012, 11:19:57 am »
I must fire up that PC to look.
What can I do with it, if so ?
stefanobilliani
« Reply #19 on: September 22, 2012, 01:24:15 pm »
Don't know , but after playing a bit with that service , I had the below picture of an error .
And I cant read the activation thing .
After going online , I must check again but it seems there will be the installation of the famous KB971033.
Of course all of this may tell you nothing . My original W7 copy is not yet activated here .So I am fooling around a bit .
Stefano
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #20 on: September 22, 2012, 02:20:20 pm »
Haha, well, I wouldn't fool too much around if I were you !
stefanobilliani
« Reply #21 on: September 22, 2012, 03:37:56 pm »
haha , you're right . I have another copy full activated .  Happy
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
