![](http://www.phasure.com/Themes/SandBox/images/post/xx.gif) |
« Reply #15 on: December 03, 2012, 02:15:16 pm » |
No. It is working on purpose like this. But I don't recognize a thing of what you say ... Of course many situations exist or may exist that something messes up in the audio engine. But nothing like "when I play somewhat longer, stop and want to play again, it won't work unless XXEngine3.exe is killed".
So maybe you can recognize what the specificness is about your issue ?
« Reply #16 on: January 11, 2013, 02:20:56 pm » |
By the way, I tried the Sotm Card with W8, but the same happens... I play one or a few songs all in a row, all is good. When I press PLAY the next time = reboot... I am beginning to have a collection of items that I am trying to apply to other tasks Alain
« Reply #17 on: January 11, 2013, 02:29:33 pm » |
Alain, is that with 0.9z-8e ? Remember, when you talked about such (similar ?) issues earlier it appeared to be the same in W7. But this is solved now in one of the later z-8 versions.
« Reply #18 on: January 11, 2013, 02:51:10 pm » |
I tested it with 9-8, but as for the letter, I will have to verify... I did not write this at the right time, since I am not with W7... Please disregard it for the moment...
« Reply #19 on: January 12, 2013, 03:03:40 pm » |
Ok, what I reported is with 9-8e... After having this problem for so many months, I don't consider it urgent, as I have other means to play music. I am just disappointed having paid for a card that seems "difficult" to use. Maybe one day I will have a surprise ![grazy](http://www.phasure.com/Smileys/default/crazy.gif) Alain
Tore
« Reply #20 on: April 19, 2013, 10:20:04 am » |
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #21 on: April 19, 2013, 12:29:55 pm » |
Hi Tore, Thanks a lot ! I will try it and report back Regards, Alain
