December 22, 2024, 05:21:38 am *
Pages: 1 2 [3]  All
Author Topic: 0.9z-7-3 Sample Rate not set  (Read 31732 times)
« Reply #30 on: September 24, 2012, 06:45:57 pm »
Well, the important part is :
You set your OS scaling to 125% which is not compatible with XXHighEnd's scaling. This is why you have the anomalies (like that vertical bar right trhough everything). This is why I told (in that other topic - where I would like to move these posts to if I knew where to be) that you should set the OS to 100% and XXHighEnd to 125% (1.25) if you want that size. Then all works fine. But additionally, right after using the Scale functionality (or apply a Preset for that matter) the screen is not correct (like the MinOS button lacking). So, quit XX and restart it to get that right again.
Besides, when you use the Scaling of XXHighEnd a bit larger than 100% (1.00) those lacking "numbers" will be there (like in the Preset buttons in the left).
Now, if you can find that other topic for me ...
Ok yes i understand this. I have been playing around lately to see what works the best for me. But this is clear. I will set it to 100%
Whas it this one?
http://www.phasure.com/index.php?topic=2257.0
Thanx  Happy
praphan
« Reply #31 on: September 24, 2012, 07:06:08 pm »
This is why I told (in that other topic - where I would like to move these posts to if I knew where to  ................
Are you looking  for this topic?
http://www.phasure.com/index.php?topic=2170.0
Praphan
« Reply #32 on: September 25, 2012, 09:14:53 am »
LOL. It's both. But Praphan, your is this very topic ... haha.
Ok, I'll let it stay in here.
Pages: 1 2 [3]  All
