November 23, 2024, 10:23:15 am *
Author Topic: PA will not engage playing 24/96  (Read 19265 times)
« Reply #15 on: September 15, 2012, 02:52:03 pm »
I have never updated from 9Z-7. With PA engaged with High Res material I have to be very careful, as I can get some very loud ticks and plops if the volume is too high and I either hit stop or I try to change the volume. With 16/44 material upsampled 16x with XXHighend, the noises are minimal. The The High Res sound is exceptional though: classical music from High Definition Tape Transfers. What I don't understand is why 16X upsampling in the software results in such quite noises (ticks and plops) while native high res, not upsampled at all, gets a bit dangerous.
« Reply #16 on: September 15, 2012, 03:26:46 pm »
Easy - and the same as has been explained before when "all" thinks it is engaged while it is not : it fades out in the wrong direction (because it should not fade out at all). So, at this moment (0.9z-7-3 or eearlier) : only use PA and Hires when it is upsampled (to any rate).
stefanobilliani
« Reply #17 on: September 15, 2012, 03:50:15 pm »
Hi Peter ,
looking at your pictures in this topic , one question comes to mind :is Peak Extend essential with Phase Alignment?
stefano
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #18 on: September 15, 2012, 05:58:39 pm »
OffTopic
Stefano - Coincidence : I just today finally solved the "distortion" issue with Peak Extension (because I found a way to measure that). And yes, at this moment (0.9z-7-3) I sure would use Peak Extension. For 7-4 it won't matter anymore.
