November 23, 2024, 04:29:19 pm *
Author Topic: Hard Disk Message - new  (Read 7824 times)
stefanobilliani
« on: September 10, 2012, 08:24:33 pm »
Hello there Peter and all .
Can you please address me to the meaning of the message listed below?
Thank you .
S
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #1 on: September 10, 2012, 08:50:46 pm »
Ha Stefano ! Tells me nothing ! Must be some kind of generic message ...
What were you trying to do here ?
stefanobilliani
« Reply #2 on: September 10, 2012, 08:56:54 pm »
The message pop up by Pushing the button on the image below , at a very first set up of 0.9z7   3 . So at pointing to the music disc , but when the fields was clear .
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #3 on: September 11, 2012, 08:26:24 am »
Stefano,
Do you recognize that "\Device\Harddisk3\DR4" yourself ? If so, what is it ?
To me this looks like a device you must have accessed before clicking that button; probably from one of those other same buttons in XXHighEnd. Then, after being done with that, you removed that "whatever" and at a next usage for such a button it defaults to your last accessed drive, which now is not there anymore. Hence the error (???).
So, I am not saying that you did that, but something like that would explain the message (which I never saw myself and will be a general Windows message).
But how did this get solved (message not appearing anymore) ?
stefanobilliani
« Reply #4 on: September 11, 2012, 02:50:27 pm »
Stefano,
Peter , thanks for the reply .
The message goes away the second try or by clicking retry and easily the normal explorer comes back . so not a problem .
To answer your question , no I do not recognize the device but your ipotesis may be true since I did play with a ide/ata to sata converter thing recently ; that was for an old Maxtor HDD expolration .
BTW everything , and I say everything is working properly for now . From unattended to minimized to PA , everything is just fine .
s
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
« Reply #5 on: September 11, 2012, 08:54:26 pm »
Hi Stefano,
And the funny thing is, you can thank yourself for it.
But on the behalf of others, thanks too. You'll understand ...
