November 23, 2024, 12:34:55 pm *
Author Topic: 9Z7-2 Still crack Issue Phase Alignment  (Read 5388 times)
« on: September 04, 2012, 05:14:22 pm »
In my case 0.9z7-2 hasn't solved the problem of a couple of clicks at start of the first track,  neither a louder click after 10 seconds  & neither a couple of loud clicks after 20 to 30 mins of playback. CPU doesn't indicate any abnormal activity.
Tried increasing Q1 to 30, SFS to 60, but no change.
Any suggestions?
« Reply #1 on: September 04, 2012, 08:13:07 pm »
Hi Arvind,
Not related to what has changed in 0.9z-7-2.
Are you sure you set the "SFS Rounds" high enough to cover for this 10 seconds ? If so, what would be your calculation ?
Okay ... not fair ... what are your RELATED settings (this *is* fair, because it is necessary to understand (ehm, you yes)).
« Reply #2 on: September 05, 2012, 10:30:30 am »
It was my mistake I overlooked the feature of SFS rounds, now I have set it to 4 & the clicks at track start & 10 secs into the track have stopped.
Thanks.
