November 23, 2024, 11:35:57 pm *
Author Topic: Can't uncompress the dongles setup zip file  (Read 10265 times)
« on: August 31, 2012, 02:24:40 pm »
I have downloaded the zip file twice to verify if it was the download, but still...
« Reply #1 on: August 31, 2012, 03:49:23 pm »
Alain,
If I see it correctly you are trying to unpack it with 7Zip. Possibly this does not work for (this) RAR. I have had no other complaints ...
« Reply #2 on: August 31, 2012, 04:01:04 pm »
I know (about the only one complaining)... I tried with the std Windows 7 utility (through context menu), then with "The Extractor", then "7zip")... Retried with each of them after downloading 2 more times... It is the first time it happens (with W7, SP1)... I will try it with my laptop just to check if it is a problem with my "all purpose" PC or...
« Reply #3 on: August 31, 2012, 04:03:02 pm »
I had an error too having a damaged file without par files to be able to repair it. I downloaded it again (using a direct link to the download this time) and that one was okay and unpacking did not give any problems.
No problems unpacking it but installing (can't get it installed properly on my PC) or even make it work using my laptop is something else, too many fails so far making me stop and do something else.
« Reply #4 on: August 31, 2012, 04:10:46 pm »
Hi Bert,
By "direct link", do you mean the one sent by Peter, or one located somewhere else (if so, can you indicate me the link ?) ?
Thanks.
« Reply #5 on: August 31, 2012, 04:40:57 pm »
I have created a new one (this time a RAR, while the other one was a zip). So :
The other one ends at _7.zip
replace that for the new one with _7a.rar
and download it.
PS: There is no "direct link" to elsewhere.
« Reply #6 on: August 31, 2012, 06:05:34 pm »
and download it.
Thanks Peter, all is well installed. Now the fun begins - make them communicate + RDC Wink
« Reply #7 on: August 31, 2012, 06:10:15 pm »
Champagne ? better wait ...
prankster
« Reply #8 on: September 03, 2012, 04:00:02 pm »
I forgot to say that all works fine with RDC and I like it a lot more than with ThightVnc ! Happy
Page created in 0.252 seconds with 19 queries.
