November 23, 2024, 06:55:20 pm *
Author Topic: 0.9z-7-2 OS doesn't minimise  (Read 9236 times)
« on: August 31, 2012, 07:55:22 am »
This is the first version in which I am unable to Min OS. Is it a bug or is there a different procedure than what is mentioned in the tutorials?
« Reply #1 on: August 31, 2012, 08:01:05 am »
Hey Arvind,
Nothing changed and it just should work (and does so here).
Maybe you are not properly Activated ?
« Reply #2 on: August 31, 2012, 08:21:22 am »
I had the same problem but after going to normal OS using the previous version of XX and properly activating the new version I was able to go minimised again.
Not the most user friendly way to update XX though but in the end it worked out for me.
nik.d
« Reply #3 on: August 31, 2012, 08:46:06 am »
Gd. morning
At first attempt to minimize I received "Error #1" msg in XXHE. Second attempt
few seconds later (after clicking away err message) succeeded w/out problem
« Reply #4 on: August 31, 2012, 09:54:25 am »
Hey Arvind,
Like the earlier versions I copy pasted the Activation code (dat file) into 0.9z-7-2 folder. So I guess this was wrong, I need to once again enter the activation code & follow the Activation procedure. Is this the way?
« Reply #5 on: August 31, 2012, 10:02:05 am »
Arvind - It is not wrong but it does not help. What should help is Activate your 0.9z-7-2 again with the Code you already have.
I don't think this is written anywhere, so sure it is not your fault ...
But does this help ?
« Reply #6 on: August 31, 2012, 03:19:19 pm »
Activation solved it. Thanks.
