November 23, 2024, 06:41:20 am *
Author Topic: 0.9z-7-1 problem  (Read 5589 times)
« on: August 29, 2012, 05:54:35 pm »
To those who downloaded 0.9z-7-1 :
Don't use it with Phase Alignment; The new parameter mentioned in the Release Notes incurs for wrong results when held to 0.
0.9z-7-2 is available now ...
« Reply #1 on: August 29, 2012, 07:59:10 pm »
I was too quick, thanks for the 2nd update...
...one problem though. It stops playing after 15 minutes or so and as far as I can see all is activated.
The previous version 9z7.0 was nicely activated from start.
I could be wrong though (seeing red borders and such).
Should I go through Paypal again or..?
« Reply #2 on: August 29, 2012, 09:11:33 pm »
Problem seems to be solved! I activated XX again with the number I received before and followed the activation procedure further down the line(s).
Not sure if that did the trick but it is playing okay now and the borders look like they should acording to the description.
Minimising did not go so easy either but that is working okay too again.
