November 22, 2024, 09:39:54 pm *
Author Topic: Ignorance sucks + which HDD for Win 7  (Read 32721 times)
« Reply #15 on: September 01, 2012, 03:48:26 am »
Nice choice Happy
« Reply #16 on: September 01, 2012, 04:09:08 am »
wheew
Should I still partition this drive?
Western Digital VelociRaptor 250GB 10000 RPM 64MB Cache SATA 6.0Gb/s 3.5"
50 GB seems small now, but really/literally the only thing on this will be Win 7 pro & XXHE.  When I set up galleries again I'll be picking up an SSD Later.  So 50 GB partition is the right size to choose for best imaginary performance of XXHE?
« Reply #17 on: September 01, 2012, 04:49:57 am »
I would. 50GB should be ample for XXHE use only.
I have always advocated that the system drive only needs to be as big as required to accommodate the operating system files and intended program files used, with a little margin for normal growth due to system logs etc. User data should be directed to another partition or drive. This philosophy also allows independant backing up of system and data.
Having a small partition created for the O/S will maximise performance, as that partition will utilise the outside of the platter(s), presuming that is the first partition you created. You can create a second partition on the drive using the remaining space and use it for incidental files, such as install files or as a work space when organising your latest rips before copying to your final music folders.
« Reply #18 on: September 01, 2012, 07:24:03 am »
Thanks Russ
Just installed an old 74 GB Velociraptor for the playback drive and formatted
format G:/fs:exFAT/q
I show hidden files but just chose to go here first.  Don't know exfat vs ntfs, but I guess it doesn't matter.  Thought fat was older and limited naming?
Anyway
Should I partition this drive for the Playback?  Size?
« Reply #19 on: September 01, 2012, 07:42:18 am »
I'll defer to Peter for the total size needed, but I would think 10GB should be plenty for the playback drive, unless you want to queue up a weeks worth of listening Wink
It's probably advisable to use 64K sector sizes also. And omit the /q from the command. For a drive this small, and the fact that's its an older drive, forcing the system to verify that each physical block in intact is worth the few minutes extra needed. When using the /q you only recreate the file allocation table, which is why it is much quicker.
format G: /A:64K /fs:exFat
Peter ??
« Reply #20 on: September 01, 2012, 08:35:25 am »
The formatting of the Playback Drive is only needed when those hidden files without the proper rights to them are in the way (and XXHighEnd produces an error about the Playback Drive). Otherwise it's all self-contained.
When you format it anyway, not performing a "Quick Format" like Russ said, could be a good idea. Just to check the drive. But do it right before you go to sleep because it may take an hour (or two).
I would not put another partition on the Playback Drive. Never mind it will be too large then.
PS: Your choice for the OS disk hould be very okay for speed Dave. Personally I make my OS partitions always 90GB; just experience. So, at some stage (OS upgrade) the normal space is needed another time. Plus it should not be too full (trashing). 90GB *is* on the large side, but why not.
« Reply #21 on: September 01, 2012, 06:20:12 pm »
http://www.phasure.com/index.php?topic=2029.0
"Warning : Do not make the mistake to format all your disks with the largest block size possible. So, something like the Operating System's disk contains many small files of a few bytes up to a few hundred bytes only. If *that* disk now would be formatted with a 64KB block size, all these small files will occupy 64KB on disk. So, now all takes enormously much more space on disk (10s of 1000s of files)."
So when I format my OS/XXHE HDD (bearing in mind only XXHE will be on there; not galleries not PlayBack)
What
Allocation Unit Size:
would be best?
Just Default? or something else between 512 and 64K?
dave
« Reply #22 on: September 01, 2012, 06:38:44 pm »
I use 512 ...
