November 24, 2024, 05:24:00 am *
Author Topic: Save plops at stopping for Prodigy HD2 users  (Read 20732 times)
« Reply #15 on: August 25, 2012, 07:59:57 am »
It wasn't brought up yet, but it is true that a next start of the same album does not exhibit the crack. So be careful with your testing of this.
And indeed it will be what Juan experienced.
Thank you Praphan.
« Reply #16 on: August 25, 2012, 01:27:38 pm »
I got the plops too at the end, really loud!!!!
This happened after I changed buffer from 4096 to 1024, SFS from 60 to 2 , Mixed, rest default.
The sound is really amazing, more inner detail, like you can hear easily if it is Whitney singing or an imposterer.
(Not that I tried this Wink )
But those plops at the end need to go, so what is the  directions we have to go to get them out? Higher Buffer, SFS, Q, Qfaktor(what's that?) or? More memory, faster processor?
« Reply #17 on: August 25, 2012, 04:45:38 pm »
Eh, what about reverting that ? yes
In addition I can say that from theory Mixed is not the best for this, because it is really slow. Hard to explain further, but you might want to try Straight Contiguous as a first attempt to solve it (and merely to learn from).
phantomax
« Reply #18 on: September 10, 2012, 08:57:28 pm »
No more plops at sttoping. After trying different settings with Z7-3  finally I could do it: SFS 4 Q1 30 Q1x 4. These are very good news because getting up to down the volume slider in the Prodigy panel before every stop/end was quite annoying.
 Good job !
But at the same time I have notice something weird: moving that volume slider when XXHE is playing produces a noise like if it was an age-worn potentiometer. I have noticed too that that kind of VU meters in the Prodigy panel doesnŽt show the real levels anymore  as they are always at maximum while playing. wacko
Some Prodigy's users out there with the same issues?
Best regards
Maxi
« Reply #19 on: September 11, 2012, 08:48:31 am »
Hi Maxi,
To me this looks like the Prodigy's driver volume fights the Windows volume. So, one of them is fooled by the XXHighEnd output and settles on e.g. -20dB (which might be false) while the other thinks it is -22dB. This is no problem as long as neither volume slider is used. But as soon as one of them is used -and they are connected internally- they both want to settle for their own setting and they bounce upon eachother (therewith really the volume changing rapidly - and which might be what you hear for "noise").
You can easily check whether this is caused by Phase Alignment (which you did not suggest at all) by deactivating it and looking at it again.
phantomax
« Reply #20 on: September 11, 2012, 09:35:05 am »
IŽll check later if it depends of PA being active or not ( I think yes ) but for sure in the previous version ( 9z 7-0 ) there were no noise with PA active in unattended mode ( I kept the Prodigy panel active to control the volume ). But I must say that I never used the XXHE volume control before because I was afraid of the presumed noise. With this version I felt more confident to try it and is totally silent. Only in unattended mode there are little ticks and delay but I think is as it should be. So maybe is time to forget the Prodigy panel and that's it.
Regards
Maxi
