November 22, 2024, 10:45:37 pm *
Pages: 1 2 3 [4]  All
Author Topic: Problems with RDC  (Read 44434 times)
« Reply #45 on: August 29, 2012, 12:28:59 am »
Thanks Mani for taking your time to help while travelling. Yes I used the Bluetooth IP address in my case 169.254.167.40
Peter, I tried also the LAN On in XX and with the DNS of the Ethernet LAN, in my case 192.168.1.136, from the PCMUSICA (Audio PC), entered in the CONTROLREMOTO PC (de laptop I use as remote). Same error message.
Maybe here could be an explanation: I see that the PCMUSICA (Audio PC) has a sign of ! in one of the screens. It does mean that it doesn´t have installed the drivers, it needs a driver called "Fresco Logic xHCI (USB 3.0 controller)", but on the other hand as can be seen in that screen the Unknow Device (Dispositivo desconocido) pops up a window saying that "There is no need for more drivers or the driver were already installed". At the end all quite confusing.
Tomorrow, if you don´t see something that could help in the screens, I´ll remove all the RDC installation and I´ll start again.
Thank you again and best regards,
« Reply #46 on: August 29, 2012, 12:39:09 am »
I post here some more screen prints, this time from the CONTROLREMOTO, the remote laptop.
Thanks again,
« Reply #47 on: August 29, 2012, 02:00:57 am »
G'day Juan,
perhaps the following FAQ from microsoft's site might help ...
http://windows.microsoft.com/en-US/windows7/Remote-Desktop-Connection-frequently-asked-questions
There is also a short video tutorial link on that page that may help.
Good Luck!
« Reply #48 on: August 29, 2012, 10:56:48 am »
Thank you Russ,
I´ve already read that and there is where I´ve found that maybe Windows 7 Starter could be unable to get remote communication from other computers but, if I understand it well, not to connect remotely from there to other computers as I think that it should be.
Please see the screen print "Which editions of Windows 7 include Remote Desktop Connection"
My laptop (CONTROLREMOTO) is running Windows 7 Starter.
I´ll wait to see if I receive some other opinion and if not I´ll install it again.
« Reply #49 on: August 29, 2012, 11:05:59 am »
A small remark in between from my side :
I tend to call the "host computer" as how it's undoubtedly officially named, the "Audio PC" while that other thing is called "the remote" by me. That wouldn't be correct according this (again, of course official description).
It is well known that any version of Windows can be used as the client, but to be honest maybe I didn't even know before shortly that also something like "Starter" existed. And, like from "Home", all kind of features do not exist in Starter and they are not always (well) documented. It seems doubtful though, that Started wouldn't allow to be a client (while the client software is clearly in there).
But it must be something of course.
At least I am glad for you that by now you have seen that it is unrelated to the Bluetooth connection. This makes things a lot more simple (and more confident, not only for me).
The answer is still to be found, sadly ...
« Reply #50 on: August 29, 2012, 11:46:53 am »
I believe your interpretation of the bullet points is correct and that is how I read it also. You SHOULD be able to initiate the connection from your laptop.
Networking can be frustrating at times, and it's one of the less enjoyable aspects of PC's that I enjoy! My recent exploits getting my laptop with Vista on it to work with RDC is a prime example. I lost more grey hairs getting that working as desired, but perseverence paid off in the end. I'm sure you'll get there also soon.
« Reply #51 on: August 29, 2012, 12:36:07 pm »
There is something else, which has been on my mind for a longer time (for this topic) already, but I thought it wasn't possible. I just asked around, but it is :
It *is* possible that Firewall software on the host PC blocks internal IP traffic. This is not normal (to do) but technically it can exist.
Eh, for now, turn all off in the host PC which smells like a Firewall ?
