« on: August 22, 2012, 10:33:46 pm » |
Hi all, I'm kind of reluctant to post this here, because it really doesn't have anything to do with XX, but I'm trying to get RDC working via bluetooth and am having problems.
The two computers see each other no problem. But RDC refuses to work. I will go online and do some research myself, but if anyone has an obvious fix, please let me know.
Cheers, Mani.
« Reply #1 on: August 22, 2012, 10:44:23 pm » |
ALL SORTED!
It was just a matter of sorting credentials out.
Mani
« Reply #2 on: August 22, 2012, 11:32:46 pm » |
NOT ALL SORTED!
I'm having problems connecting with the computer name '169.254.108.156'.
When I thought everything worked OK, I was connecting using the name of the AudioPC (MAIN-HIFI-PC in my case) and not '169.254.108.156'.
Connecting via the name of the AudioPC works fine if the AudioPC is not in Minimize OS mode. But as soon as you go into this, the connecting PC cannot find AudioPC.
I cannot connect using the name '169.254.108.156' irrespective of whether the AudioPC is in Minimized or normal OS mode.
Any thoughts?
« Reply #3 on: August 23, 2012, 12:58:55 am » |
I've managed to get everything working in Minimize OS mode!
BUT...
... it only works if I have 'Keep LAN services' ON. This is not an ideal situation - even though I have unplugged the LAN cable from the AudioPC I would prefer it if I could switch 'Keep LAN services' off.
Any thoughts?
stefanobilliani
« Reply #4 on: August 23, 2012, 07:35:04 am » |
Hi, I had the same impossibility to connect my laptop exactly as described in manis' post . Later in the afternoon will try to change credentials too and see if it works . NOT ALL SORTED!
Any thoughts?
Mani
May 27 -2013 , 0.9z-9
W8 pro 64bit, UEFI sata ahci mode . i7 (8 cores ) 2600k RAM : 16Gig XXHE on OS disk Music on OS disk Playback drive on USB3 to 4Gig Pendrive Mobo USB 3 to Oversampling dac at 2X KS adaptive , ArcPredict , dev buffer 1024 Q1=8 , Q5=3 , res 1msec Minimized OS , stop all services X-tweaks : 45,100,1,1,1, stable , optimal Disk Utilization : Split File Size: 120 ,max the same as SFS Memory Organization : Straight Contiguous
« Reply #5 on: August 23, 2012, 07:56:51 am » |
Hi Stefan - Peters IP address did not work for me either. I used the actual ip address of my PC which is different to Peters. Mine works with the LAN services off so don't know what to suggest there.
« Reply #6 on: August 23, 2012, 09:38:42 am » |
ALL SOLVED!
If you have problems establishing an RDC connection when the AudioPC is in 'Minimize OS' mode, then you need to connect using the AudioPC's IP address. To find this:
- make sure bluetooth PAN has been established (see tutorial) - run the command line (cmd) in AudioPC - type 'ipconfig'
This will give you the IP address of the bluetooth connection. In the connecting PC (laptop, or whatever else you're using), use this address in the RDC window, and NOT the one Peter states in the tutorial OR the name of the AudioPC (this will work, but not if LAN services are off). I attached a screen shot of mine, but of course your IP address is likely to be different.
HTH.
« Reply #7 on: August 23, 2012, 11:00:26 am » |
Woops …
So this is my bad. I figured the IP address of the dongle at the main PC's side was fixed, but apparently it is not. I obtained it the same way (via IPConfig) ...
Thank you for sorting it out ! Peter
« Reply #8 on: August 23, 2012, 11:06:24 am » |
Mani (or others), a stupid question maybe :
Since I am not there to check it out literally, and since I tried to update the Tutorial for it, at what recognizable ipconfig line should one look for the Bluetooth IP address ?
Thanks a lot. Peter
« Reply #9 on: August 23, 2012, 11:26:34 am » |
Here's what I get...
PS. But note that this is for the BT-PC not the Audio-PC (the latter is not connected to a LAN and it's too much hassle to transfer a screenshot).
« Reply #10 on: August 23, 2012, 11:50:15 am » |
I used the "Autoconfig IPv4" address and it works fine
P
« Reply #11 on: August 25, 2012, 02:44:17 pm » |
I installed the driver from the e mail on the audio PC & laptop. However neither computers are able to locate each other. I rechecked the driver download, both seem ok but the problem persists. Any suggestions?
« Reply #12 on: August 25, 2012, 04:38:09 pm » |
Hello Arvind, I assume you precisely followed this Turorial about it : Set up BlueTooth PAN. Now, I recon that when it now doesn't work, somewhere along the lines of this process something didn't work out as described. So, where was that ? If you think it was all okay, I am afraid you will have to do it again so you can run into whatever it is. If you are 100% sure that all when exactly as described, well, then I don't know, but you *still* need to tell where it stopped being in alignment with the description. All in other words : it should just work. If not, then I can't do much with the (no) data provided. So I hope you can find something for me ... Regards, Peter PS: To be sure we talk about the same thing later, maybe add a screen copy of where things don't align. Can be a copy of the picture in the Tutorial along with a picture of how your screen looks at the same time.
« Reply #13 on: August 25, 2012, 05:18:51 pm » |
Attached are 2 screenshots from the Laptop.
Identical pictures from the audio PC too.
Hope these help.
« Reply #14 on: August 25, 2012, 05:37:09 pm » |
Arvind, I am sorry but you now showed the status of how you have it. Can you answer my previous questions please ? Thanks.
Regards, Peter
