November 22, 2024, 10:01:28 pm *
Author Topic: Save Library Result List error  (Read 5197 times)
« on: August 22, 2012, 08:44:01 am »
hey Peter,
I have been following the tutorial on saving library search lists ( http://www.phasure.com/index.php?topic=2057.0 ), but every time I right click on the "F" (Favorites) button, I get an error message box appearing that reads "No Library Files found in the Data Folder". If I left click on the button the Favorites list appears, so that part works OK.
I have tried it on 2 on my PC's here and the error is the same on each.
Any idea what I am doing wrong ?
ta ..
« Reply #1 on: August 22, 2012, 09:16:33 am »
Oops. That seems like a bug to me.
To avoid it, copy a random file (could be a Notepad .txt file) in there and rename it to *.LBRY. Now you will have the access. Of course don't read back that Notepad file;
Once you created a result list, the Notepad file can go again.
Thanks Russ,
« Reply #2 on: August 22, 2012, 09:27:08 am »
That fixed it Happy
