April 05, 2025, 05:48:18 am *
Pages: 1 2 3 [4]  All
Author Topic: Playback drive drive  (Read 63847 times)
« Reply #45 on: September 12, 2012, 11:07:22 pm »
In my system, the sound of music ripped directly to the OS drive (3tb, 7200 rpm, UEFI interface, true SATA III cable) is better than everything I've tried as a playback drive.... you may read that there is no difference between a true SATA III cable and a SATA II cable. Perhaps regarding speed that's true; regarding sound it's not--the SATA III cable, here on my system, makes a very big difference.
Could you tell me please what´s the brand name/model of your 3tb 7200rpm drive and the SATA III cable?. A link to the products (Amazon or any other place) will be appreciated.
« Reply #46 on: September 13, 2012, 02:48:06 am »
Here's the hard drive: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148907
My cable came with my Corsair AX650 PS, but you can get them anywhere: http://www.newegg.com/Product/Product.aspx?Item=N82E16812119473&nm_mc=KNC-GoogleAdwords&cm_mmc=KNC-GoogleAdwords-_-pla-_-NA-_-NA
The SATA 3 cables have a metal locking clip.
« Reply #47 on: September 13, 2012, 08:09:06 pm »
Here in Spain I can only find the Seagate Barracuda ST3000DM001, I really don´t know what´s the difference with your STBD3000100 model, do you?
ST3000DM001: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148844
Thanks, Juan
« Reply #48 on: September 13, 2012, 08:36:15 pm »
Hi Juan, other than the ST3000DM001 being 50 dollars cheaper and warranty differences I don't know. My drive, STBD3000100,  has a 5 year manufacturers warranty if its made in Thailand, the Chinese version only has a one year warranty. Looks like the one you found only has a one year warranty.
« Reply #49 on: September 13, 2012, 08:48:54 pm »
Here in Spain that drive has 2 years warranty, maybe I´ll buy it to to see if your "madness" makes any sense.  Wink
Best regards, Juan
« Reply #50 on: September 13, 2012, 09:23:06 pm »
Sounds good, but I can't guarantee results, especially with a different MB and processor. Sure hope it works for you!
« Reply #51 on: September 14, 2012, 12:01:52 am »
Just a quick note. Please check the warranty... It used to be 3 years standard and 5 years for more expensive and durable drives... I see a lot that only carry 1 year now...
stefanobilliani
« Reply #52 on: September 14, 2012, 03:57:30 pm »
Well , thanks to your suggestion Boleary ;
I have been able to install Windows 7 Sp1 ,with a GUID partition table UEFI interface to a 250Gig Sata disk .
What is interesting , is that the sound I hear is much better than before . Well that could be some other factors , but the disks are similar , and many other things are similar too .
I did not activate yet , because I need to make some choice for the future .Probably a new HDD;  the result is very very promising anyway . I like it .
stefano.
May 27 -2013 ,  0.9z-9
W8 pro 64bit, UEFI
sata ahci mode .
i7 (8 cores ) 2600k
RAM : 16Gig
XXHE on OS disk
Music on OS disk
Q1=8 , Q5=3 , res 1msec
« Reply #53 on: September 15, 2012, 04:39:14 am »
So glad to hear you've had a good experience! One of the things that I've noticed here is that anything other than a SFS of 2 doesn't sound right.
« Reply #54 on: September 18, 2012, 10:01:44 pm »
I´m looking for the "perfect" hdd for Playback Drive. So far I´m looking for an external hdd because I want to test different connections.
These are the minimal specifications the hdd must have in my opinion:
- USB 3.0
- External power supply
There are other specifications I´d like to investigate, to see the influence on SQ, like:
- rpm speed
- the size of the cache
- other connections besides USB 3.0, like eSata.
On this regard I think that the Freecom Quattro could be a good candidate, mostly because it is a very silent drive and with eSata and USB 3.0 (besides FireWire). The problem, if it is a problem, is that it has only 8Mb cache size and that the speed is 5.200rpm. It is an expensive drive but the 1tb size is cheaper and enough for Playback Drive: http://www.amazon.co.uk/Freecom-2TB-Quattro-FireWire-External/dp/B004Z610M2/ref=sr_1_2?ie=UTF8&qid=1347991616&sr=8-2
I´d like to know some opinion about what could be the importance of the cache size in the Playback Drive. About the rpm speed I´m almost sure from my experience with other hdds that it is not the main issue.
« Reply #55 on: September 21, 2012, 07:33:07 pm »
I wonder if anyone has tried a WD Caviar Black for Playback Drive?. It seems to be appropriate for it because it is quite fast: 7200 RPM, 64 MB cache, and SATA 6 Gb/s interface.
Among the defects that can be attributed to the WD Caviar Black is that it seems to be quite noisy.
